2009 gmc sierra Service hybird want start need help
Old Mar 10, 2019 | 09:20 PM
2009 gmc hybird's Avatar
Default 2009 gmc sierra Service hybird want start need help
My gmc sierra hybird has a message that came up and said service hybird and will not start any help would be appreciated
Old Mar 10, 2019 | 10:16 PM
Default Re: 2009 gmc sierra Service hybird want start need help
Check 12V with load tester and check codes.
Old Mar 11, 2019 | 04:36 AM
I put another 12v battery in it and still no start but there is no codes thanks for the reply
Old Mar 11, 2019 | 09:22 AM
Unless you're using a professional grade code reader, there are a lot of hybrid system specific codes that your average consumer code reader can't check. If your car says "service hybrid system" as you indicated, then YOU HAVE CODES.
Old Mar 11, 2019 | 07:34 PM
Chicago38's Avatar
Welcome to the club of those who do not start Tahoe
Old Mar 11, 2019 | 08:48 PM
I have had many problems out of this truck new transmission new lifters and cam and now the service hybird is on and will not start
Old Mar 12, 2019 | 07:54 AM
Hillbilly_Hybrid's Avatar
You need to begin with data... codes
Old Mar 16, 2019 | 08:30 AM
dnt1010's Avatar
Sounds like you have had a LOT of wrenches turned on this vehicle.
I am not sure how recent the transmission work was? but if this were mine I would check the basic/easy stuff.
1. Pull the hybrid battery disconnect and reinstall it being 100% sure it is fully engaged and all 3 steps are done.
2. Do an underbody crawl and check ALL the electrical connectors that you can find especially around the transmission.
3. Check the hybrid battery voltage just for grins and giggles.
4. I guess at this point if I find nothing wrong I would call whomever (stealership?) did the other work to help with it?
nikkrae101
General Motors Corporation
Feb 20, 2026 09:44 PM
lvflyer
60
Oct 8, 2022 03:41 PM
Quincy Tjador Oshiro
Jan 5, 2020 04:45 PM
chkuttner
Nov 29, 2016 10:25 AM
emdsd
Jun 16, 2009 09:12 PM
