2008 Tahoe Hybrid Codes POAC4 and P061B
Old Dec 9, 2012 | 07:48 PM
  #31
ponsta12's Avatar
Default Re: 2008 Tahoe Hybrid Codes POAC4 and P061B
UPDATE:
Finally, got a call back from GM after many days of playing phone tag. Customer Service didn't have any answers...told me to get a second opinion! Really??? I'm done with these guys. What a joke.
Hybrid was acting up today again...put the car in Reverse and CEL came on and 'reduced engine power' and 'service traction' something???
Old Dec 10, 2012 | 03:51 PM
  #32
Hillbilly_Hybrid's Avatar
So take it or tow it to a different dealer and insist that they read ALL codes and obtain the Freeze Frames to send to GM.
Old Mar 9, 2014 | 09:44 PM
  #33
jimr5454's Avatar
I'm interested in a gm extended warranty .08 Yukon hybrid 112000 miles but new Gm motor factory installed. About what will that cost?
Old Mar 10, 2014 | 05:58 AM
  #34
I think GM warranty is only until 100k miles. you might need an aftermarket one.
Old Mar 10, 2014 | 06:48 AM
  #35
jimr5454's Avatar
Correct only to 100,000 .aftermarket warranty $3000.seems like allot and $100 deductible .eeeeeks should I throw caution into the wind?
Old Mar 10, 2014 | 07:55 AM
  #36
I paid $3500 on majorguard gmpp and it did not cover the front shocks. make to read what is covered and what isn't.
Old Aug 17, 2016 | 08:25 PM
  #37
greenfreek's Avatar
any good news on yukon/tahoe hybrid issues?
Old May 19, 2017 | 05:52 PM
  #38
Twobillion Ks's Avatar
Originally Posted by ponsta12
I'm having a problem with my Tahoe Hydrid Stalling out. It happens when the engine switches from Electric mode to Gas pode particularly at a stop. The codes that show up ar POAC4 and P061B. I've taken the vehicle to the dealership numerous times and they were not able to fix it. First time they said the throttle body was dirty and it needed to be cleaned. That didn't fix it. Next time it happened they said the batteries were no good, but they couldn't work on the Hybrid since the gloves that they use to work on Hybrid batteries had Expired. Then the next time it happened they said it was the Catalytic Converter...that was change and it still did not fix the problem. I took it in the last time just recently and they reflashed the ECM and said they still don't know what is causing the problem...they supsect it is the aftermarket wheels and tires that is causing the vehicle to stall? The advisor said that Hybrids are very sensitive when it comes the the computer and torque calculation. Does anyone have any idea of what it causing this problem???
Thanks in advance.
Hello. I am having the exact problem you described. I was wondering how things turned out. Thanks for your time.
Old May 20, 2017 | 02:12 PM
  #39
Fun Times's Avatar
Hi, welcome to the Green Hybrid Forums.
Below is just some additional basic info for POAC4 on the GM Hybrids,
https://www.autocodes.com/search_codes.php?q=POAC4 <You'll need to scroll down.. Plus even though it doesn't really matter, there's one for Chevy, GMC, Cady, and others which is all almost the same but all the info combined is a little helpful to help understand the problem a bit better.
P061B:
From the following link regarding P061B is some copy and paste basic info, https://www.autocodes.com/tsb/gmc/sierra_1500/2008.html
Bulletin Number: PIP-4686Bulletin Date: 09-01-2010Component:
Engine and engine cooling:engineSummary
Chevrolet/cadillac/gmc: hybrid driveability or customer concerns of flare, slip, stall at a stop, surge, lack of power, poor fuel economy, reduced ev range/limited electric propulsion, dtc p061b after campaign 09102b or dtc p061b prior toBulletin Number: PIP-4686Bulletin Date: 09-01-2010Component:
Fuel system, gasolineSummary
Power train:automatic transmissionSummary
061000 engine and engine cooling:engineSummary
070000 fuel system, gasolineSummary
103000 power train:automatic transmissionSummary
Not sure if the following would be related but worth knowing about none the less as this requires a new module, http://www.autoserviceprofessional.c...brid-bump-jerk
Old Jun 20, 2017 | 01:24 PM
  #40
tiktok4321's Avatar
It sounds like when these two codes are offered together, a battery fix is necessary.
Interestingly, I can't get freeze frame data when my Tahoe jerks, freezes and shuts off, turning on the check engine light. By the time I can get to a dealer to get freeze frame data pulled, the light goes off, and no data is available. I don't reset it, it "fixes" itself.
I need to find a local battery refresher.
