2008 Tahoe Battery Performance
Old May 12, 2016 | 08:27 PM
Default Re: 2008 Tahoe Battery Performance
40kW @ 288V nominal is 139A... not much higher than the Prius given the lower voltage of the Prius.
Again, 1V is WAY too high. Anything larger than 0.3V at the currents captured is out of sorts. Even at 120A, I've never seen more than 0.6V momentary deltaV.
$2400? That's Freaking cheap.
Old May 13, 2016 | 06:37 AM
Hillbilly_Hybrid's Avatar
$2400 when you give them the old battery. ~ $1500 core charge.
And yes a good battery behaves just like you said.
Old May 13, 2016 | 06:40 AM
That's still a fantastic deal. It's literally exactly the same as a Lexus battery in terms of the type and number of modules. The Lexus battery is way up there.
It's less than the Prius battery with only 28 modules. Camry battery is WAY more with only 34 modules.
Kudos to GM for their sensible pricing...
Old May 13, 2016 | 04:52 PM
Just need some folks out there bench testing modules and swapping out the weak ones for these guys.
The Allison Hybrid Bus used six ( 6 ) 40 module packs on the roof. It has its own air conditioning system.
ilovelucy
Nov 4, 2015 08:29 PM
CSL
General EV Discussion
Mar 12, 2009 12:58 PM
MartianMan
Jan 14, 2009 07:00 AM
Vyncynt
Jul 29, 2008 01:30 PM
pitokhato
Apr 12, 2007 11:29 AM
