10 diagnostic trouble codes. Ten! pls help
Old May 12, 2015 | 07:06 AM
T.Brew's Avatar
Default Re: 10 diagnostic trouble codes. Ten! pls help
OK now it won't go into gear, could the noise I'm hearing be the transmission? Codes that came back on are
Multiple misfires -confirmed
Cold start emission reduction control systems confirmed
Heated o2 sensor heated resistance bank 1 sensor 2(the one I replaced)-pending
Random multiple mis-pending
Another cold start ERCS- pending
I could not hear any sucking type noises under hood, and the transmission is overfilled, and there is leaking coming from right above front cross member drive shaft input
Old May 12, 2015 | 09:56 AM
Hillbilly_Hybrid's Avatar
I don't remember you describing a noise. Engine on/off. Periodic knocking?
Old May 12, 2015 | 10:52 AM
T.Brew's Avatar
Well I just thought it was the miss. Knocking I'd say. I have a video but I can't upload it for some reason even only 2 second vid
T.Brew's Avatar
Engine on . periodic knocking while it runs only a few seconds then it dies/ or just auto offs
Old May 12, 2015 | 11:37 AM
Even stops with hood open? The engine should stay on with the hood open or shifter in M.
If it quits with hood open, that's bad.
May need to get to an engine shop.
Old May 12, 2015 | 12:10 PM
T.Brew's Avatar
****. Yes stops with the hood open every time... Well thanks for all your help I guess I'll get it to a shop. Should it only be a hybrid certified mechanic at a.dealer ,or can I go to my normal shop?
Old May 12, 2015 | 01:25 PM
The engine is an engine for the most part. There are some hybrid specific parts. If it is quitting with hood open that is a shut-down of the hybrid system.
So for fundamental engine mechanical diagnosis a good Small Block Chevy tech will do.
Old May 12, 2015 | 01:29 PM
T.Brew's Avatar
OK thanks will let you know what happens
Old May 20, 2015 | 11:38 AM
A battery problem?
Old May 20, 2015 | 11:51 AM
T.Brew's Avatar
I know your just trying to help but did you read all of the post? I suppose it could be an additional problem. but black wet spark plug #1 cylinder and the missing/dieing every time it is started points to a little more serious problem. It was dropped off to the car lots mechanic on Friday of last week I haven't heard anything yet.
