'09 Yukon Hybrid lurch from Auto Stop to Engine
Old Aug 14, 2019 | 09:50 PM
Tahoe_08's Avatar
Default Re: '09 Yukon Hybrid lurch from Auto Stop to Engine
It's actually normal for this to happen .. I would just put a tow hitch on there just in case a dumb idiot driver is following too close.
the hitch square is the first device to get hit anyways screw you California adding the ball changes NOTHING
Old Sep 4, 2019 | 08:49 PM
Tahoe_08's Avatar
Actually Check the battery Terminals on for the 12vDC
mine were loose and dirty they were flapping around in the wind (who ever installed it did a bad job)
the 12V had a engine off voltage of 11.9 (which is a fully discharged battery) with a OBD2 reader
DIC was reporting 12-13 with the engine on
after cleaning and making sure they were nice and sung it's reporting 15Volt-DC in the DIC
these Aux transmission pumps relies on the 12Volt battery and NEED high AMPERAGE and high voltage to run correctly 14.9volts 14.5-14.9volts
this is the only way the first and second gear can be primed... and ready
Just have some eye protection and banking soda mixed with water just in case you get battery acid on you...
these are cheap insurance and highly recommended if it shows any signs of acid leakage ..
before loose cables low voltage
Old Aug 31, 2020 | 07:44 AM
coreyhuggins's Avatar
Originally Posted by Tahoe_08
you can always bypass AutoStop by using M4 to disable auto surge feature
still get the good mpg
How do I do this? Thanks
Old Sep 2, 2020 | 04:13 AM
dnt1010's Avatar
Originally Posted by Monza
You can spin tires in Hybrid mode or Manual?
Just regular drive and this is with oversize tires works best if you weight shift a bit (these things weigh 6000lbs) but throttle is very responsive and the Nitto Grapplers make a very large bark when rubbed against a pavement surface LOL. I try not to exercise the ole HO too much she has over 229k on her but she still has the "Kick" if you need it or want it.
Old Dec 1, 2020 | 06:42 PM
Stollchc2's Avatar
Do you mean under the hybrid battery?
can you give me (a noob) a description on how to do this?
Originally Posted by lt1gmc
I have corrected this problem a few times on my 09 by unplugging the connector that goes to the aux trans pump and replugging it in. I believe it resets the pump control module, similar to disconnecting the battery. I later found my 12 volt under hood batteries cable loose. Retightened and unplugged-replugged the connector for the aux pump module and havent had an issue since. Been 65,000 miles. The connector is under the battery and above the steering box, 4 larger wires, blue, red, yellow and grey.
firefighteremt777
General Motors Corporation
Dec 29, 2025 08:09 AM
PBRLives
62
Mar 4, 2021 01:55 PM
dszx13
Jun 25, 2018 06:35 AM
jimr5454
Sep 6, 2016 05:07 PM
