08 Yukon hybrid died while driving. Won’t start
Old May 26, 2019 | 09:21 AM
Twobillion Ks's Avatar
Default 08 Yukon hybrid died while driving. Won’t start
I was driving at city speeds. Accelerator became unresponsive. I came to a stop. Removed the key, then inserted and attempted to restart the truck and it will not crank. 12v is good. All lights and electrical work (except time display). Do I just need a new HV battery? Thank you very much for your help.
Old May 26, 2019 | 05:32 PM
Jaime's Avatar
Default Re: 08 Yukon hybrid died while driving. Won’t start
First thing to do is connect a scanner to the OBD2 port to read any codes set by the computers. That will give clues as to what the cause of the problems is.
Old May 27, 2019 | 06:40 AM
robmck's Avatar
Hi..
Have you checked to see if your vehicle has had the transmission controller changed? Some early models of 2008 hybrids had a faulty part which meant the engine would not crank, and when driving everything would come to a stop. It happened to me with my 2008 Tahoe about 6 months after purchase. In the US this is a warranty item. Once replaced the problem has not re-occurred.
Hope this helps.
Rob
Old May 14, 2023 | 05:56 PM
Roger1212's Avatar
Originally Posted by robmck
Hi..
Hope this helps. Hello what part did you change mines keeps doing that ***** turns off out of. No where even on the freeway I changed the air sensor and the one next to manifold also
Rob
Old May 14, 2023 | 08:59 PM
???'s Avatar
I think by transmission controller he means the TCM. transmission control module. I believe it's inside the tranny case on these trucks. no clue how hard that would be to change and it would probably have to be programmed to the truck by a dealer level scanner after install.
Ptaylor85
Oct 2, 2019 05:43 AM
dbmartin55
19
May 10, 2017 06:55 PM
Derekc
13
Apr 12, 2014 09:15 AM
k0712s
Nov 7, 2009 05:52 AM
