08 hybrid tahoe stalling/ low acceleration
Old Aug 5, 2015 | 05:31 PM
  #51
Hillbilly_Hybrid's Avatar
Default Re: 08 hybrid tahoe stalling/ low acceleration
It's not so bad. I was going to start a NiMh hybrid battery re-build shop when I retire.
Unlike so many I have been around the technology a little over 2 decades in a Research and Development capacity.
I'm not going to share my "testing method" quite yet for sorting reusable cells.
But alas GM stopped building these and the newer plug-ins don't use that chemistry.
The $2700 is list price. You might try to get out the door under $2900
Good luck. The new one has changes in the computer that Panasonic did after 2009. The computer comes in the battery.
The new one should last longer.
Old Aug 5, 2015 | 06:53 PM
  #52
ilovelucy's Avatar
Thanks, Hillbilly.
Should I ask the dealership if the battery is the new generation then? I just want to make sure I don't get a "rebuilt" one from the dealership. If that's not a possibility, then all is good.
Old Aug 5, 2015 | 07:32 PM
  #53
There are NO rebuilts authorized by GM. Only new. Only the most recent programming.
The chemistry is the same. The programming has changed since 2008.
Old Aug 5, 2015 | 08:59 PM
  #54
Default 08 hybrid tahoe stalling/ low acceleration
So should my just traded hybrid with a new 300v last longer? If so, no wonder it was sold in less than a week.
Old Aug 6, 2015 | 05:15 PM
  #55
Odds are yes.
Old Sep 21, 2022 | 09:17 PM
  #56
ShaylaD's Avatar
Yes it starts up just fine. The problem only occurs randomly when I come to a stop, and then start going again, when it switches from auto stop to engine[/QUOTE]
were you able to ever find the problem to this? My car does the same thing but the only code that is presented is P0AC4
Old Sep 22, 2022 | 08:04 PM
  #57
???'s Avatar
were you able to ever find the problem to this? My car does the same thing but the only code that is presented is P0AC4[/QUOTE]
it's the hybrid battery pack most likely. get one of the 20$ obd2 port adapters, down load torque pro app for 5$. add the pids for the battery voltage from this thread and log. most likely you'll find it hurt badly. in the mean time, try driving in M4 mode, it won't go into auto stop and help keep the voltage up enough to drive fairly safely for a while longer but the mileage will be as almost as bad as a normal Tahoe.
Wireless Bluetooth Diagnostic OBD2 Scanner Car Code Reader and Scan Tool for All 1996 & Newer Vehicles ELM327 Compatible OBDII for Android Devices ONLY https://a.co/d/j8IDmoz
https://electricvehicleforums.com/fo...results-31736/
cessy1
33
Mar 19, 2021 02:38 PM
dbmartin55
19
May 10, 2017 06:55 PM
Guss
32
Dec 26, 2009 07:23 AM
Jason
Hybrid & Related News
Oct 19, 2008 07:43 PM
Inigo Montoya
Jan 24, 2006 02:03 PM
