service hybrid system
I have a 2009 chevy hybrid mode 2.
last night the truck ran fine, in the morning it wouldn't start. There is a "Service Hybrid System " indicator light on now. I changed the 12v battery, checked fuses and checked voltage from the hybrid batteries, they total 309v when i checked them. What could be the issue?
Do you really think that is the problem? 🤷♂️
If you can't be helpful just stay quiet.
you need to use an obd2 scanner and an app to figure out what the issue is but most likely your HV battery is going bad if its just an unbalanced situation doing some conditioning could extend its life but if there is a bad cell (aka blade) it is not going to work and will need
pull the codes
a cheap OBD2 might be able to get the code from the freeze frame data
lvflyer
60
Oct 8, 2022 03:41 PM
2009 gmc hybird
Mar 16, 2019 08:30 AM
Ivan Popko
Feb 16, 2019 06:44 PM
