General EV Discussion Discuss electric only vehicles (Tesla, Volt etc.)
Chevrolet Volt concept... plug-in hybrid
Old Jan 24, 2007 | 03:26 PM
  #181
bwilson4web's Avatar
Engineering first
Cool Re: Chevrolet Volt concept... plug-in hybrid
Originally Posted by bparsons
Why not have a system with solar cells on the roof to trickle-charge while parked?
Insufficient area to generate enough power to move a usable distance. However, if you had a trailer with fold-out, solar cell arrays, you could get some serious power, enough to move a non-trival distance down the road . . . with the cells folded on the trailer.
Bob Wilson
Old Jan 24, 2007 | 03:50 PM
  #182
bparsons's Avatar
Banned
Default Re: Chevrolet Volt concept... plug-in hybrid
Hence the system of trickle charging while parked
Old Jan 24, 2007 | 04:45 PM
  #183
Engineering first
Talking Re: Chevrolet Volt concept... plug-in hybrid
A light-weight version of plug-in would make sense with our NiMH batteries. They typically suffer a self-discharge over night. But the problem is 'tricking' the battery controller to recognize the higher charge state of the batteries the next morning.
One of the problems the plug-in crowd had to solve was getting the extra current into the battery / battery-bus without triggering a fault. Now it may be that bringing the batteries to their full, 80% charge level over night _MAY_ work. But I've not seen any reference to this being done.
The advantage would be to start with a 'fully charged', at 80% battery, instead of a 60% charged battery minus the last EV mode and overnight, self-discharge. But this is not a trivial problem and I would want a few extra features:
  1. Cell pack balancing - having the cells at the same charge level is more important than trying stuff as much in the pack as possible.
  2. Cell pack monitoring - I would like to indentify weak cells well before they could put the battery pack at risk.
  3. Cell pack AH actual - I would like to know how much capacity is in the cells.
This would be part of a total battery management system, not just a 'dump in some power and hope it is better.' The reason is even a 'trickle charger' can damage cells. Caution is the word.
BTW, trickle charging at night from solar cells is non-trivial. <grins>
Bob Wilson
Old Jan 24, 2007 | 04:52 PM
  #184
bparsons's Avatar
Banned
In that case, you'd need a lunar charger LOL
Old Jan 24, 2007 | 10:50 PM
  #185
Kraken's Avatar
Bob Wilson
Bob,
1) Simple function of proper series/parallel wiring (final connections are at "adjacent" points, on opposite sides of the bank)
2) Technology currently exists to closely monitor charge efficiency to the point where individual cell/battery failures are quickly revealed.
3) The same technology in #2 easily measures amp-hour state (in-out-in between) to within 1% accuracy. You can even get a computer interface, for data dumps/spreadsheets/manipulation/etc.
Old Jan 25, 2007 | 01:41 AM
  #186
bparsons's Avatar
Banned
Is this somthing that could be made cheaply and easily and sold as an aftermarket product?
Last edited by bparsons; Jan 25, 2007 at 01:41 AM. Reason: fingers too big, hit too many letters
Old Jan 25, 2007 | 02:58 AM
  #187
Engineering first
Wink Re: Chevrolet Volt concept... plug-in hybrid
Originally Posted by Kraken
Bob,
After I design and add it to my Prius it will. These functions don't exist when the car is 'off' although the elements are evident in the mini-scanner data. The battery management system I'm thinking of works from house power, a plug-in lite, and works 'offline' to maximize battery health.
Bob Wilson
Old Jan 25, 2007 | 06:41 AM
  #188
Kraken's Avatar
Bob Wilson
Exactly. This type of system has already been designed & perfected in the marine industry (house power/offline).
Old Jan 25, 2007 | 07:25 AM
  #189
ag4ever's Avatar
Dazed and Confused
So if a "series" hybrid is a good idea, why have we not seen somebody take a car and dump the ICE, replace it with some motors, a battery pack, and then install a honda generator as the powersource? Would two EU200I linked geneartors providing between 3200 and 4000 watts of power be enough to keep a car going down the road?
http://www.hondapowerequipment.com/M...elName=eu2000i
I undestand these generators to be very efficient and relatively clean.
See: http://www.hondapowerequipment.com/M...elName=eu2000i
Old Jan 25, 2007 | 07:44 AM
  #190
bparsons's Avatar
Banned
That sounds possible, but what about the fuel used in the generator? I'm not sure that a generator is cleaner than today's automobiles.
