Wheel size vs mpg
Old Nov 4, 2019 | 05:37 PM
Jean-Thomas Landry's Avatar
Default Wheel size vs mpg
Hello i have 19 rav4 hybrid with 17inch wheel oem 225/65/17 25 pounds
I want to switch for 20 inch wheel 27 pounds 245/45/20
I do 40 000 miles by year... gas millage is really important for me! You think iTs gonna be the same or worse??
Thx JT
Old Nov 4, 2019 | 06:52 PM
Default Re: Wheel size vs mpg
Worse. Heavier with a higher angular momentum. Will take more energy to spin them up. You may also be limiting your tire choice to less optimal LRR choices.
Your speedo will read 0.6% low.
Old Nov 13, 2019 | 02:36 PM
Tahoe_08's Avatar
it's not going to make a difference on the mileage,, but the ride will be more rough.. as you have less side wall to deal with..
Old Dec 8, 2019 | 04:06 PM
Hillbilly_Hybrid's Avatar
You are going to lose some simply due to the wider tire... Cross sectional area and drag coefficient.
You can't change physics. Learned that the hard way long ago with K5 Blazer. Lift kit, bigger wider tires and I doubled the horsepower.
Lost top speed.
Riceball777
Mar 1, 2015 10:51 AM
civicnleo
Dec 24, 2011 12:27 PM
UWAdventurer
Jul 8, 2008 04:50 AM
bwilson4web
18
Mar 20, 2008 02:46 PM
BigBill
Aug 16, 2005 09:27 AM
