Ford Motor Company Ford, Mazda and Mercury hybrids
HELP!!! 08 FEH no idea what's wrong at this point
Old May 10, 2022 | 01:34 PM
wykeishla's Avatar
Angry HELP!!! 08 FEH no idea what's wrong at this point
Good afternoon, we have a 08 FEH that has not started almost 3 months. It started with the yellow wrench coming on twice and deciding to get a tune up. Went and got an oil change and decided to order the cargo air filter on Friday. By Monday on the way from the store, we exit the parking lot at normal speed, red triangle, yellow wrench and SSN: immediate shutdown. Try to restart, no luck. Towed back from the store, try to jump start with the button, no luck. Got the hookup charger, tried to get it at least charged, not even charging. What could be wrong? What am I doing wrong? Is there anyone in NC that can help? I'm at the end of my wits because right now we have a paperweight instead of a car.
Old May 10, 2022 | 07:14 PM
Default Re: HELP!!! 08 FEH no idea what's wrong at this point
The Yellow wrench indicates you need to do professional grade diagnostics.
Recommend you get Forscan.
Old May 12, 2022 | 04:16 AM
wykeishla's Avatar
I forgot to say, I ran Forscan and the codes that came up were:
TCM P0A7A-FF
PCM P1000-FF
PCM P1A0D-FF
PCM P1A10-FF
BCM P0A95-60
HVAC B12A7-20
HVAC B12B2-20
Old Apr 2, 2024 | 10:59 AM
DeanMassye's Avatar
AlexK
Jun 13, 2021 04:13 PM
TeeSter
Mar 30, 2009 11:55 AM
travelover
Sep 21, 2007 05:47 AM
Method
Dec 7, 2005 05:03 PM
nysebull
Sep 9, 2005 02:08 PM
