Headlight replacement on Ford Fusion Hybrid first generation (2010)?
Old May 21, 2017 | 06:36 PM
swechsler's Avatar
Default Headlight replacement on Ford Fusion Hybrid first generation (2010)?
Anyone ever replace their own headlight bulbs? According to the manual, dealer service is required; however, the assembly looks somewhat accessible. Driver's side would require removal of the 12V battery while passenger side, the radiator overflow tank. I just bought the FFH over the weekend (for my son) and nothing's burnt out yet, but I want to be prepared. Previous owner gave me her receipts and I didn't see anything for bulb replacements (it's possible she didn't give me everything), so I'm anticipating needing a replacement soon.
Old May 22, 2017 | 05:53 PM
Milan_OH's Avatar
2010 Milan Hybrid
Default Re: Headlight replacement on Ford Fusion Hybrid first generation (2010)?
I replaced my passenger side by turning the wheels full left and popping a couple darts to peel back the wheel well liner. You can get your arm in there far enough to remove the connector and bail to R&R the lamp.
Old May 26, 2017 | 05:59 AM
lolder's Avatar
I think the bulbs last a long time. There's no need for a precautionary replacement. If and when it happens you'll probably have forgotten how to do it. YouTube will probably have the answer then.
Old May 26, 2017 | 06:28 AM
swechsler's Avatar
Thanks, I took a look and it seems doable. There appear to be rubber covers over the rear of the assembly. Do they just slip off?
And did you do the driver's side?
Old May 26, 2017 | 06:29 AM
swechsler's Avatar
The car's got 93k miles on it; even with LL bulbs and without DRLs, that's a long time for bulbs to last. I'd rather do them now than have my son bring it to a mechanic.
Old May 31, 2017 | 08:23 AM
Milan_OH's Avatar
2010 Milan Hybrid
I only replaced the passenger side.
I don't specifically remember a rubber boot, but I'm sure it slides away / pulls off. If it were an issue, I'd remembered something difficult, and it wasn't.
You'll be working by feel once you shine your light in there and assess the landscape.
Mine blew after I had a remote start installed, and....pretty sure the installers nuked it somehow.
Old Feb 23, 2019 | 12:14 PM
Mike Reese's Avatar
I just bought a 2010 Fusion..haven't even made the first payment, and have had to replace a taillight and licence light, and now a headlight...but having had a 2008 Fusion (not hybrid) that was totaled two years ago, I know about the oddball headlight business. It's a pleasure to see that I can still go through the wheelwell. I don't mind going to a dealer for work above my ability, but a headlight bulb? C'mon. I would strongly suggest getting a panel tool as someone else mentioned....you will save a lot of cursing and perhaps injuries.
Old Mar 2, 2019 | 11:42 AM
Mike Reese's Avatar
Angry Re: Headlight replacement on Ford Fusion Hybrid first generation (2010)?
Like Fred Allen, I am now having to talk to myself by responding to my own post. I tried to get through the wheelwell on the driver's side yesterday; The clips were a pain to get loose, and I finally gave up when I couldn't get any leverage to pull a couple deep inside the well...so...I'm going to try the engine bay way. Fortunately I have small hands (haha), so I may be able to snake my way under the air filter area after loosening some bolts. I hope. Completely mystified at Ford changing the design that was on my '07 (totaled) with a door you could open in each wheelwell to get to the bulbs. There can't be THAT much dealer profit in bulb changes, can it?
Old Mar 2, 2019 | 11:57 AM
swechsler's Avatar
Hey Mike, is it possible that the difficulty lies in the fact that it's a hybrid and the layout of the engine bay is different from that of a standard ICE vehicle? As I'm sure you know, the 2008 and 2010 are the same body style; it seems unlikely that they would have changed something like that.
Old Mar 2, 2019 | 11:02 PM
Mike Reese's Avatar
Hmm...no, there are differences in the body styles between the '08 and '10. Now, the basic platform might be about the same, but you are right about the engine bay, the air filter on the hybrid is more complex ( I probably won't be touching that too soon) and there are two coolant tanks. I was able to move part of the air filter hose today and snake my hand under to change the driver's light, but the passenger side will have to wait until I have more time to pull the wheel well liner off and reach up under. I tried moving the overflow tank, but decided against taking the hoses loose. It was just too tight even with taking it out part way to get to that light.
