Why the rear drum brakes on the '09?
Old Jun 3, 2008 | 03:03 PM
08FEH's Avatar
Default Re: Why the rear drum brakes on the '09?
There is always a slight drag on disc brakes.
08FEH
Old Jun 3, 2008 | 04:09 PM
steved28's Avatar
Originally Posted by KenG
As risky as it is to disagree with "How Stuff Works", I'm going to.
Well smartass, One thing I can say is that I have performed dozens, maybe hundreds, of brake jobs in my 50 years. When the wheel is off the floor, and I spin it, it drags on a disk brake system. Just how many disk brake jobs have you done? I don't need "HowStuffWorks" to look this up, I knew it, but I figured I would at least include one reference.
Old Jun 3, 2008 | 05:01 PM
stevedebi's Avatar
I read the article referenced - it was a study on how groove design can affect drag. Apparently the design of the caliper and the type of rubber material can change the characteristics of the disc brake, and one of their conclusions is that the harder the disc brake is used, the more likely it is to be close to the disc after use (i.e., drag).
One question - if there is drag, why is the disc brake preferred - is it cooler, more efficient, less complex?
Old Jun 3, 2008 | 05:30 PM
KenG's Avatar
Gee Steve, I thought we were having a discussion.
In my 60 years I've done lots of drum brake jobs but never a disc brake job because I've only had to replace them a couple of times on warranty when I had warped rotors .
I'll defer to your experience but, if the drag is significant, why isn't there enough return spring force added to eliminate it? It seems like a 10 cent part.
Old Jun 3, 2008 | 08:16 PM
steved28's Avatar
We are, but I made the reference to HowThingsWork, and you mad a smartass remark about it, thus me calling you a smartass.
The drag is not significant. And I assume auto manufacturers are willing to give up that lost energy. After all, there is so much lost energy in heat due to the braking process itself, why quibble about a little drag. Just give that truck some more HP. And the pad wear would be insignificant. I suspect that this area will be revisited now that we want to squeeze out all losses in newer, more efficient vehicles. Perhaps it already is done, I have just never seen one (with a return spring).
Old Jun 4, 2008 | 07:41 AM
MyPart's Avatar
I still stand by my original statement that the inherent "wobble" of the rotor during cruising speeds keeps the pads off the rotors for a large portion of the time. How else do you explain water's short term effect on braking performance in a disc system? If there were substantial friction wouldn't the water evaporate or be pushed off without pedal effort?
Also, as highly engineered as the FEH is to increase FE, I can't see why Ford wouldn't put a return spring in the caliper if this really were a measurable drag event. At the least they would have mentioned it since they took the time to measure the FE effect of running the radio.
Mark: Isn't the weight and rotational mass of a hub system greater than that of a disc system? Especially in a drag racing scenario where super light, thin, rotors can be used.
Old Jun 4, 2008 | 09:30 AM
  #27
Mark E Smith's Avatar
Omnia Gloria Fugit
Drum brakes on stock and super stock weigh less than the stock disc system. Discs are far superior in heat dissipation so I dont think the circle track or road racers would want drums. The aftermarket brake systems used on professional classes are a different animal.
The way discs are designed with the disc piston area 5-6 times the area of master cylinder piston, every little bit of travel is magnified. I have never seen a return spring on a disc setup.
Old Jun 4, 2008 | 10:45 AM
  #28
wwest's Avatar
Brake fluid is incompressible.
Wrong, patently incorrect.
Two examples.
As a kid we used to put a matchstick head in a coke bottle full of water and then cause it to sink into the water by using our thumb to "compress" the water.
Many VC's, Viscous Clutches/Couplings use a specially formulated (high rate of volume expansion when heated) fluid enclosed in a hermatically sealed container. As the clutch plates "stir" the fluid it heats and absent the ability to expand the viscosity increases thereby increasing the coupling coefficient between the clutch plates.
While driving the brake pressure is essentially atmospheric. When the pedal is depressed the master cylinder increases the pressure, When the pedal is released, the system goes back to the original state. If it doesn't, a vacuum is created and either the pad is pulled back or more fluid is sucked in from the master cylinder reservior.
No, the brake fluid actually compresses slightly along with the brake lines expanding (very slightly) due to pressure and then collapsing when the pressure is released.
Looking around on the Internet, I found this paper on finite element modeling of a disk brake system (which was submitted to the Society of Automotive Engineers):
http://www.simulia.com/download/solu...c03_delphi.pdf
In the abstract it says:
"The rubber seal performs the dual function of sealing the piston bore
and retracting the caliper piston after a brake apply."
In the standard disk brake system the seal does act as a return spring. If the piston bores become corroded/dirty, this may not be enough and the brakes drag. If you do an internet search you will find many patents for supplementary return spring systems to minimize this drag. My recollection is that some cars have implemented some of these systems and it was advertised as an improvement a few years back, but I can't seem to find that. One of the features of the 2008 Dodge trucks is "reduced drag brake caliphers" but I don't know the details.
Old Jun 4, 2008 | 10:50 AM
  #29
wwest's Avatar
I'm now 67 and I've also done my share of brake jobs. Manually turning the wheel by hand force to overcome the force of brake pads, even fully broken in pads, does NOT equate to them rolling ~20-50 yards "at speed". And trying this with newly installed pads, high spots not yet worn down, clearly does not equate.
Oh, and almost all disc brake piston seals/boots have an integral return/retraction spring, oftentimes embedded inside the rubber seal/boot itself.
Old Jun 4, 2008 | 02:55 PM
  #30
08FEH's Avatar
Willard,
Can you specifically name one domestic vehicle caliper that you have found to have a return/retraction spring anywhere within?
If you are referring to the "ribs" in the outer dust seal, that is simply so the piston can expand out and the boot can compensate and continue keeping out the dust.
There is no caliper made that I know of to have any type of retraction spring "in the caliper"....
There is no "wobble" in the rotor either. If a rotor had enough of a wobble or high spot in it to push a brake pad away, it would also cause an undesireable pulsation.
The brake pads in a disc brake system always have a slight contact with the rotor when the brake pedal is not applied....
08feh
