Why is power to reverse only in electric mode?
Old Dec 3, 2006 | 03:33 PM
Default Why is power to reverse only in electric mode?
I recently read, power for reverse is only done in electric mode. Why is this? I'm not so sure this is a good idea for me when I repeatively go into the snow country for skiing. If I get stuck in the snow, I may not have the torque to back out of the snow.
Old Dec 3, 2006 | 03:56 PM
alan_in_tempe's Avatar
Veracitorian Muser
Default Re: Why is power to reverse only in electric mode?
Your car has no reverse gear. However, while the engine is running, it can be powering the first motor/generator to generate lots of current that can be fed into the second motor/generator to drive your car backwards. There is more torque in that motor at low speeds than your engine has, so the only limitation your car has in reverse is how fast it can go backwards, and you will have all the torque you will ever need to manage backing up in the snow. If your battery is well charged, it can provide the current the motor needs, but the battery is not needed to go backwards.
-- Alan
Old Dec 3, 2006 | 06:47 PM
Pravus Prime's Avatar
Prof. of Hybridology
https://www.greenhybrid.com/discuss/...ead.php?t=6441
It's unlikely that you'll ever get stuck in any situation where a conventional Escape could get out of.
Old Dec 3, 2006 | 07:38 PM
Tim K's Avatar
As mentioned, electric motors are actually extremely "torquey"....hence the incredible acceleration of EV's like the new Tesla sports car. That said, your speed and HP will be limited to the electric motors. The reason is that the CVT is not a traditional geared transmission and there is no reverse gear to speak of.
Old Dec 4, 2006 | 09:37 AM
wwest's Avatar
This is a bit of a puzzle, really.
Since with the unique CVT concept MG2 could clearly be used to cause the front driveline to turn backwards even with the ICE turning "forward"...
Old Dec 4, 2006 | 11:04 AM
TeeSter's Avatar
The question becomes why would you want to... at 20mph or so and below the ICE would likely be turning at low RPM, the electric motor is going to provide the most torque anyway at those low RPMs. Especially because its an atkinson cycle engine and the low end torque is pretty bad.
So instead, run the ICE at a higher RPM to turn the generator and provide full current to the motor. The only time the ICE would be at much of an advantage in reverse is if someone wants to backup at high rates of speed which I wouldn't recommend in any car. Its a 95hp electric motor... it can push the vehicle just fine in reverse at reasonable speeds. In fact someone mentioned they pushed a horsetrailer backwards just fine with it... I personally don't recommend exceeding the towing capacity like that though.
leonardochen0
HCH III-Specific Discussions
Sep 12, 2015 06:34 PM
dbtjazz
Mar 11, 2011 05:48 AM
mavidal
Honda Insight II
Aug 12, 2009 05:57 AM
NASAgineer
Oct 6, 2006 02:33 AM
