Why does EV mode not kick in?
Old May 13, 2005 | 12:42 PM
stevewa's Avatar
Early Adopter
Default Re: Why does EV mode not kick in?
We tend to group "the brakes" to include the friction brakes on the wheels and the regenerative braking coming from the traction motor. They operate in concert so it's hard to think about them individually.
Old May 13, 2005 | 01:13 PM
cdbrow1's Avatar
What scares me is the 12V to 300V jump start proceedure in the owners manaual.
I can't believe that would actually work.
Anyone want to test it for the group?
Chris Brown
Old May 13, 2005 | 06:19 PM
GaryG's Avatar
Chris, I don't think anyone would let there FEH sit for months to drain the high voltage battery to test the jump start system. If the high voltage battery suddenly went bad, a jump start with the 12 volt battery would only be temporary to get to the Ford dealership.
I agree, this is a feature to give Ford credit for. I would try it in a minute.
I am so impressed with my FEH and I can't believe I got it at the price I paid. I pay more for my kid a to attend MIT for one year ($43,000). I wish I could afford to buy him one, but soon he may be able to afford to buy his own. Hats off to our gifted engineers. This is rocket science used in the automobile finally.
Lets make OPEC understand we have the brains and don't forget it!
Old May 13, 2005 | 07:53 PM
stevewa's Avatar
Early Adopter
From what I've read in the service manual it doesn't actually charge at 300V. There's additional wiring in the battery that allows the low-voltage charger to charge the groups of cells in parallel which allows a lower voltage to be used.
Chris Brown
Old May 13, 2005 | 09:38 PM
GaryG's Avatar
Thats not what I read in the service manual steve. I understand that the 12 volt battery dumps its charge in the High voltage battery as a one time attempt to start the FEH engine. Jump starts from other vehicles to the 12 volt battery system can be made also to charge the high voltage battery to FEH for a start up.
Old May 13, 2005 | 10:32 PM
stevewa's Avatar
Early Adopter
Actually, you get two tries...there's enough capacity in the 12v battery to run two cycles of the jump-start system.
Of course I can't find the detailed info on the HV battery I got this detail from, but from what I recall inside the battery each tube of cells (I think it's 5 cells to a tube) is individually monitored and wired to the jump-start charger. When you push the jump-start button it charges all of the tubes (I don't know if it does them simultaneously or sequentially) to a pre-determined value, which is just enough to start the engine. It also provides heat inside the battery pack to get the cells closer to optimal operating temperature.
So for normal operation, the battery cells are wired in series, but for the jump-start operation it's parallel. If you think about it this makes sense as the system can reduce the change of reverse charging a cell, which is especially likely when the battery is nearly flat.
I know one person on the Yahoo board has experimented with the jump-starter trying to use it to boost his battery for extended EV use. Of course, it doesn't put enough power into the HV battery to make a significant contribution.
Old Oct 16, 2017 | 12:07 PM
Nolberto Gonzalez's Avatar
Originally Posted by jnr
I love slowing down and seeing the needle drop to EV, sitting at stoplights with no gas engine running, etc. What I can't figure out is why this sometimes does not happen. Normally, anytime I slow to 30 mph the FEH goes into EV mode. Once in awhile, though, I can't MAKE it go into EV mode. Even when I come to a complete stop the gas engine keeps running. I can't see anything different. The ambient temperature is the same as it was the day before (when the FEH went into EV mode regularly), I've been driving the same as always, the message center says the available energy is NORMAL (I've never seen it say LOW), the vehicle has been running long enough that the engine is definitely warmed up, and I'm not running AC or defrost.
Does anyone have any idea why this happens? I don't have the NAV system so I have to rely on the message center for my information. When this happens it goes on for most of my drive to work or home again (a 35 minute drive). It's very frustrating. I keep thinking of all the unnecessary gas I'm using!
Blue HiHy
Feb 13, 2014 08:13 PM
ericbecky
Events & Gatherings
May 2, 2008 09:37 AM
shu246
Apr 28, 2008 07:55 PM
ben_hch
Aug 23, 2006 05:58 PM
