Vibration at 2000rpm - 2009 FEH
Old Aug 8, 2010 | 05:59 AM
wptski's Avatar
Imported from Detroit
Default Re: Vibration at 2000rpm - 2009 FEH
Originally Posted by 08FEH
You are the man, but it's an 09.
We sold our 08 to buy it, and we are reminded of that mistake every single day.
Your Hybrid vehicle still shows a '08.
Okay, here's TSBs for '09 FE/FEH
10-13-3
FM RADIO RECEPTION/SOUND QUALITY CHANGES WHILE DRIVING OR SATELLITE RADIO SIGNAL BLEED THROUGH WHEN USING AUDIO SYSTEM IN AUX MODE
10-13-2
STEERING COLUMN POP/CLUNK NOISE ON TURNS - BUILT ON OR BEFORE 6/11/2010
10-13-1
WASHER NOZZLES LEAKING FLUID ONTO HOOD WHILE DRIVING
10-12-12
6F35 TRANSMISSION - 5TH GEAR ONLY - AFTER USING GRADE ASSIST ON STEEP DOWNGRADE - DTC GROUPING P072F, P073A, P073B OR P07A8, P07A9, P07AA, P0731, P0732
10-12-7
VIBRATION/STEERING WHEEL NIBBLE - COLD TEMPERATURES
10-11-5
3.0L - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DIAGNOSTIC TROUBLE CODE (DTC) P013A AND/OR P013C - POSSIBLE EXHAUST LEAK
10-10-1
6F35 TRANSMISSION - NEW DIPSTICK AND FILLER TUBE KIT IS AVAILABLE - BUILT ON OR BEFORE 10/29/2008
10-9-4
6F35 TRANSMISSION - FLUID LEAK - SEAL - LEFT SIDE HALF SHAFT
10-8-6
CLIMATE CONTROL TEMPERATURE VARIATION FROM SIDE TO SIDE - BUILT BEFORE 12/17/2008
10-8-4
SYNC - CALL SOUND QUALITY/BACKGROUND NOISE ISSUES AND/OR VOICE RECOGNITION DIFFICULTIES WHILE DRIVING
10-7-4
MALFUNCTION INDICATOR LAMP (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) P0741 AND/OR P1744 - BUILT ON OR BEFORE 8/23/2008
10-6-3
SIRIUS RADIO AND NEXT GENERATION NAVIGATION CONCERNS - BUILT BEFORE 3/8/2010
10-5-3
EXTERIOR HEATED REAR VIEW MIRROR GLASS CRACK WHEN MIRROR DEFROST IS POWERED ON - BUILT ON OR BEFORE 03/31/2009
10-5-1
LIFTGATE OPENING UN-COMMANDED OR NOT OPENING WHEN COMMANDED WHEN PARKED - INTERMITTENT
10-3-5
2.5L - 10-20 SECOND EXHAUST NOISE AFTER OVER NIGHT SOAK (EXCLUDES HYBRID)
10-2-8
SYNC SYSTEM DEFAULTS TO OR STAYS IN PRIVACY MODE, MULTIPLE VEHICLE LINES
10-1-9
FRONT AND/OR REAR CREAK/SQUEAK NOISE
10-1-7
6F35 TRANSMISSION - DTC P0720, P0722 HARSH ENGAGEMENTS OR SHIFTS, 5TH GEAR DRIVE AWAY - BUILT ON OR BEFORE 11/25/2009
10-1-3
HYBRID ONLY - DTCS P0442, P0456 OR P1450 - BUILT ON OR BEFORE 4/6/2009
09-26-12
FRONT GRILLE - CHROME PEEL
09-26-8
SYNC SOFTWARE UPDATE - VARIOUS ISSUES
09-25-3
6F35 TRANSMISSION - HOOT TYPE NOISE AT LOW SPEED - ON LIGHT ACCELERATION FROM A STOP BEFORE THE FIRST SHIFT
09-24-7
EXTERIOR DOOR HANDLE DIFFICULT TO OPEN/HANDLE NOT SITTING FLUSH WHEN RELEASED/HANDLE STICKING WHEN OPENING DOOR - BUILT ON OR BEFORE 9/1/2009
09-24-2
CLICK/POP NOISE FROM FRONT STABILIZER BAR END LINK AREA WHEN DRIVING OVER BUMPS - BUILT ON OR BEFORE 10/9/2009
09-23-5
MALFUNCTION INDICATOR LAMP (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) P2135 - BUILT BETWEEN 6/22/2009 - 10/15/2009
09-23-3
CLOTH SEAT STAINS WITH WHITE RING OUTLINE - BUILT ON OR BEFORE 5/14/2009 - (EXCLUDES XLS)
09-22-19
ENGINE NOISE, DRONE/MOAN SOUND 1800-2300 RPM - BUILT ON OR BEFORE 8/10/2009
09-21-6
WHITE FLAKES COMING FROM A/C VENTS
09-20-16
ALL WARNING LIGHTS ON IN INSTRUMENT CLUSTER WITH MULTIPLE CODES
09-20-15
WINDOW SQUEAK - BUILT ON OR BEFORE 8/6/2009
09-20-13
6F35 TRANSMISSION - RECREATIONAL TOWING - VEHICLE WITH ALL 4 WHEELS ON THE GROUND - EXPANDED GUIDELINES TO PREVENT TRANSMISSION DAMAGE
09-20-6
MIL ILLUMINATED - DTC P013A - POSSIBLE EXHAUST LEAK - BUILT ON OR BEFORE 6/24/2009
09-20-3
ABS MODULE SELF-TEST CREATING A SLIGHT VIBRATION IN ACCEL/BRAKE PEDAL AT 12 MPH (20 KM/H) AND/OR 42 MPH (68 KM/H)
09-19-15
IGNITION KEY BINDING IN IGNITION CYLINDER WHEN TURNING TO START POSITION ONLY - BUILT ON OR BEFORE 8/3/2009
09-19-5
6F35 TRANSMISSION, DTC- P0770, P0772, P0773, P0774 - BUILT 9/8/2008 TO 9/26/2008 - MIL LAMP ON - ERRATIC SHIFT AND/OR HARSH ENGAGEMENTS
09-18-4
MANUAL TRANSMISSION CLUTCH WEAR - MEXICO ONLY
09-18-3
6F35 - HARSH 3-1 OR 2-1 ROLLING STOP DOWNSHIFT - HESITATION DURING LOW SPEED MANEUVERS - 2-3 OR 3-4 UPSHIFT FLARE COLD STARTS - NO DTCS
09-17-8
3.0L INTERMITTENT CYLINDER HEAD CAMSHAFT KNOCK/THUMP NOISE
09-15-1
TRACTION CONTROL LIGHT WITH DTC C1440 - BUILT 6/1/2009-6/10/2009
09-14-3
SYNC FUNCTIONS INOPERATIVE, DTC U3000-41, U0485, OR U0100, AND/OR BATTERY DRAW WITH ACCESSORY PROTOCOL INTERFACE MODULE CONNECTED
09-13-8
3.0L ENGINE MIL ON - DTC P0011, P0012, P0021, P0022 - BUILT ON OR BEFORE 4/22/2009
09-12-16
4WD, AUTOMATIC TRANSMISSION - WHINE NOISE 60-70 MPH (96-112 KM/H
09-11-10
SATELLITE RADIO (NON-NAVIGATION) - INOPERATIVE WITH BLANK MESSAGE DISPLAY AND NO CODES - BUILT BETWEEN 12/03/2008-5/09/2009
09-11-9
NAVIGATION RADIO - WHEN ON IN CD MODE - TIME DISPLAYS TWICE IN THE FDIM
09-11-8
SYNC WITH 911 ASSIST AND VEHICLE HEALTH REPORT (VHR) DEALER UPGRADE SOFTWARE
09-10-3
6F35 AUTOMATIC TRANSMISSION TORQUE CONVERTER KNOCK - BUILT BEFORE 8/29/2008
09-8-9
RED TRIANGLE ON AND STOP SAFELY NOW MESSAGE - DTC P1A0C
09-8-6
6F35 TRANSMISSIONS BUILT BEFORE 10/6/2008 WITH NO CRANK AND/OR DTC P0706, P0707, P1702
09-6-7
PARKING BRAKE PEDAL WILL NOT FULLY RETURN WHEN RELEASED - INDICATOR STAYS ON
09-6-5
NOISE - FRONT STRUT AREA
09-6-2
2.5L WITH AUTOMATIC TRANSMISSION - ROUGH IDLE IN DRIVE - COLD ENGINE
09-5-8
ROTATIONAL CLICKING NOISE FROM 17 INCH CHROME WHEEL CLADDING - BUILT BEFORE 2/1/2009 - EXCLUDES HYBRID
09-5-5
LEFT FRONT ABS SENSOR CONTACTING TONE RING - VEHICLES BUILT 10/21/2008-10/31/2008
09-5-1
LOWER CONTROL ARM BUSHING INSPECTION PROCEDURE
09-4-4
PTU VENT BOLT LEAK - MISDIAGNOSED AS PTU SHAFT SEAL LEAK
09-1-1
COLD START FRONT END ACCESSORY DRIVE (FEAD) WHINE / WHISTLE NOISE
08-26-10
DIFFICULT TO DIAGNOSE EVAP DTCS P0442, P0455, P0456, P0457 - BUILT ON OR BEFORE 8/1/2008
08-23-12
FRONT DISPLAY INTERFACE MODULE (FDIM) - OUTSIDE TEMPERATURE DISPLAY TOGGLES BETWEEN FAHRENHEIT/CELSIUS
08-21-2
SYNC SOFTWARE PROGRAMMING SERVICE TIPS
08-20-3
MALFUNCTION INDICATOR LAMP (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) P013C AND/OR P013A - BUILT PRIOR TO 8/18/2008
Old Aug 9, 2010 | 05:01 PM
colchiro's Avatar
Originally Posted by wptski
How about this TSB: Attachment 1507
This is one of my few complaints about my '09, a loud engine. It's **** near deafening when the outside temp approaches zero.
Thank you!
Old Aug 13, 2010 | 07:50 AM
RayP's Avatar
Wow, this is a great discussion and may explain the difference between our two '09's. My wifes is super smooth and quiet, but mine has more noise and vibration on acceleration. I'm going to check it out further and see if it's specifically in that RPM range, hadn't correlated it before, just chocked it up to vehicle variations. But if they can fix it...RayP
Old Aug 29, 2010 | 09:10 AM
08FEH's Avatar
Update,
This is yet another repair not covered by warranty on our 2009 feh (the vibration fix). The truck now has 44000 owner miserable miles.
The repair is over 300 dollars, and will not be getting done, let it vibrate apart.
This has to be the most problematic vehicle I've ever owned. Ford's assistance has been less than helpful in the many many times we have had to bring the truck in for repairs.
Thanks again for the three page list of tsb's on a vehicle that is one year old. Go fomoco.
Old Aug 29, 2010 | 05:12 PM
LeeW0004's Avatar
Update,
Old Aug 29, 2010 | 05:14 PM
LeeW0004's Avatar
You are obviously unhappy with your FEH. We get it. BUT, those TSB's were for every FE/FEH ever manufactured--not just for the year you own.
Old Aug 29, 2010 | 08:21 PM
wptski's Avatar
Those TSBs are what's listed for '08 and '09, although a certain one may cover several MY.
Old Aug 30, 2010 | 05:19 AM
08FEH's Avatar
Thanks for clarifying that Bill.
And yes, just read some of my posts to find that we went from being incredibly impressed by our 2008 to extremely disappointed with our 2009.
We thought we were getting many upgrades and improvements with the new model year, but from the first day we got it, we were disappointed with mileage, reliability and function.
Maybe we got a lemon, but I think it's more that then people on this site are the happy ones, with fewer disappointed ones posting.
I'm well used to being the unpopular poster for typing a little non hyper miler reality, but hey the site isn't followalonglikesheep.net!
I'm the average middle class owner who's wife drives the feh 95% of the time. We drive it like every other car we have ever driven. Turn the key (when we can get it to turn) and put the truck in drive and go....
I'll just take my 08 back thanks!!
Old May 3, 2011 | 11:55 AM
thanksjc's Avatar
I am also hearing this noise in my 2009 FEH. Again, the dealer says the noise is normal. Nothing to be concern about. That is why I'm looking some posts on hoe to change the Tranny fluid, but I cannot seem to find the exact location of the Tranny Fill plug.
Old May 3, 2011 | 02:47 PM
GaryG's Avatar
I would not change the fluid because if you do have a problem, you may be voiding your warranty on the eCVT.
GaryG
