Transmission Problems?
Old Aug 21, 2006 | 07:21 AM
Wbruff's Avatar
Technology Enthusiast
Default Re: Transmission Problems?
Originally Posted by nitramjr
When you say "no power", what exactly do you mean? Does it accelerate to highway speed slower than at lower temps? Or does the high RPM concern you?
These vehicles definitely behave differently than regular automatic transmission cars. Has the behavior changed over when you first got it? Is the check engine light on at all? You can access trouble codes by holding in the button for the trip odometer select while you start the car - toggle through and see if there are any codes coming up. Do a search on here and you will be able to find the exact procedure.
Good Luck
From the 12 page booklet that came with my '05 FEH
"Unique Hybrid Operating Characteristics: ....The Hybrid battery may go through a self reconditioning process from time to time to optimize battery performance. You may notice slight changes in drivability during the reconditioning process. this is an important part of the Escape Hybrid's battery optimizing features"
I have at 17,000 miles been thru about 3 of these reconditioning experiences and have noticed exactly the same problem i.e. no horsepower and higher (4000 rpm from the i.c.e. . Could this be the problem or has it been going on for an extended period of time?
twolostminds
Nov 17, 2014 06:23 AM
tvrip
Oct 26, 2007 09:28 PM
steve04
Jul 31, 2006 12:57 PM
Adelwyn
Feb 8, 2006 07:10 PM
