Tire Pressure Monitoring System
Old Jul 18, 2006 | 04:36 PM
pquig's Avatar
Default Re: Tire Pressure Monitoring System
The NAV unit has nothing to do with the tire pressure monitoring system. I'm pretty sure that each wheel has a pickup associated with it, as the training sequence requires you to start at the driver's side front tire, then go to the passenger side front tire, and continue around the vehicle clockwise. The training procedure didn't work when the tech at my dealer tried to go to the wheels out of sequence. I'd be surprised if Ford put the wheel pickups on vehicles that didn't have sensors in the tires, but, then again, they did put in a cabin air filter system without including a cabin air filter.
Old Jul 18, 2006 | 07:35 PM
TeeSter's Avatar
Its not on the NAV screen. The ONLY light is on the dashboad near the tac if I remember right. YOu should be able to locate it by looking in your manual.
Old Jul 18, 2006 | 07:39 PM
TeeSter's Avatar
Also... if you have the light on the dash and one of the sensors isn't transmitting.... The light will stay on as a failure. So it makes sense that they would not put the pickups on a car that doesn't have the sensors (because the light would be on all the time).
Old Jul 19, 2006 | 06:18 AM
EOppie's Avatar
HEV's are your friend
Anyone have an idea on a ballpark of a cost of what it would be to add a TPMS system in?
Old Jul 19, 2006 | 06:38 AM
Kermie's Avatar
It does on a Nissan. I work for a Nissan dealer now and on all their vehicles if you have Nav, you have real time readouts of each tire, available on the Nav screen. If you don't have Nav, you have a dummy light like us. That's why I was wondering about Nav. But, you're right, I guess Ford did not elect to give Nav customers this feature.
Old Jul 19, 2006 | 07:43 AM
TeeSter's Avatar
Just so you know... in the usual case its not like these sensors give you a real time readout of the tire pressure. They only give you a warning if the pressure drops fairly low. I think I read that in the FEH its set to somewhere around 26PSI). Its far cheaper and more accurate to just use a tireguage regularly.
The intent is just to prevent people from ignoring their tires completely until they are dangerously low.
Old Jul 19, 2006 | 07:50 AM
EOppie's Avatar
Tire gauge it is then!
Old Jul 19, 2006 | 08:15 AM
pquig's Avatar
If you do a web search on tire pressure monitoring systems you can find aftermarket setups for around $400. The tire sensors alone with run you more than that from Ford.
Old Jul 19, 2006 | 09:56 AM
andyh's Avatar
So, if I were to replace wheels on an FEH with the monitoring system, does that mean the light will be on all the time???
Because we run winter tires for over half the year, I usually get a second set of rims so that the tires don't have to keep coming off and on......and it sounds like the sensors are expensive and not all that useful, at least to someone that looks at their tires pretty often.
Can the light be disabled?
Old Jul 19, 2006 | 10:37 AM
pquig's Avatar
At first I thought that you might be able to get it disabled by the dealer for a 'nominal' fee. On second thought, that might not be legal. I'd probably recommend the black electrical tape method.
