Are things really this bad at Ford?
The dealer secured my rear license plate with only two screws so that it 'flaps' at the bottom. When I went to add the other screws today (and a frame) I found that Ford only put two holes in to hold the plate! In place of the lower two there are a couple of sponge pads for it to flap against. Surely every state has four hole plates, why only two on the car? All my previous cars have had four.
Not a big deal, but the only reason I can fathom is the cost saving on the two little plastic widgets which can't be more than a nickel.
this is pretty typical of how license plates attach. My 2007 Honda civic hybrid, my wifes 2003 Toyota corolla, my friends 2003 civic hybrid... well every car I have access to is like this.
if you use the correct fasteners its not an issue.
as to the state of affairs at ford, well I have my opinion and its not very relevant so hopefully the above will help ease the frustration. I mean if toyota and honda are doing it its got to be okay, right?
i used to hate it when it rattled even when i was slamming the hatch shut; now: blessed silence.
oh, and also remember: the extra two bumper pads may have a nickel worth of material, but the vendor will target 40% markup to sell it to the manufacturer, who will easily mark it up another 40% to sell it to the dealer for installation, who will tack on another 40% at least, to sell it to you (less tax, of course
].i used that model back in the late 60s when costing out a capacitive-discharge ignition system. i couldn't figure out why dealers wanted like $120 (in 1969 dollars!) for something with about $25 in parts in it... the math works out pretty well.
I guess you guys are right and I've just been lucky with previous cars. I just did an unscientific survey in the parking lot at the supermarket and at least half the cars had only two bolts.
I added a frame to try and make it more rigid, but now it clanks even harder as I shut the hatch, guess I'll try the bending trick next. I still think two more bolt holes wouldn't hurt.
Lots of different - (good) - ideas have been offered on various threads of this forum for this issue. My solution:
Added a frame and two plastic nuts/bolts at the bottom to hold the frame and plate tightly together. Then I attached two self-adhesive, rectangular, teflon pads (the kind that go under furniture legs) to the back of the lowest portion of the plate. Not a peep since and I didn't have to attach anything to the paint.
Jason
Hybrid & Related News
Mar 18, 2005 02:24 PM
