Is there a secret to the cruise control?
Old May 10, 2008 | 07:35 PM
MrCrank's Avatar
Default Is there a secret to the cruise control?
I wonder if anyone else has this experience. If I maintain any given speed manually, I get about 3-5MPG less than if I set that speed on the cruise control. I know I am not pumping the torque pedal, but there is a definite difference.
Does the cruise control program have some hook into the power management program that makes this happen?
Old May 10, 2008 | 07:38 PM
Default Re: Is there a secret to the cruise control?
Many of us experience the opposite of what you posted--we get less MPG with the cruise control while driving on the interstate.
Old May 11, 2008 | 05:17 AM
08FEH's Avatar
I am with Mr Crank on this one...
I get the best mpg reading when USING cruise control..
I always use the minus (-) when setting... which costs me 1 mph...
08
Old May 11, 2008 | 05:58 AM
KenE's Avatar
I believe you are all correct, depending on the circumstances. In relatively flat highway driving, I vote for cruise control to win the MPG contest. Conversly, in all other driving situations, especially in hilly country, cruise control usage will lose the battle to a good hypermiler driver, practicing Driving With Load (DWL) and more coasting time. Cruise control will attempt to maintain speed going up the hill(s), at a tremendous MPG penalty. Also, the cruise control must be disengaged to coast. DWL techinique entail loosing a little speed going up hills while maintaining a relatively constant RPM. Doing this will beat the pants off Cruise control. Your instataneous MPG reading tells the story here.
Use of cruise control in Florida with a lot of flat land, probably makes cruise control quite effective most of the time. So IMHO, cruise can win at times, and lose at others. And if the driver is not concentrating on FE while driving, cruise is probably a better option.
Great hypermilers probably don't remember where the cruise control is located
Old May 11, 2008 | 08:59 AM
Pravus Prime's Avatar
Prof. of Hybridology
LOL, nice.
Personally, I use Cruise Control at times, and manually control it other times. As pointed out, it's entirely dependant on the terrain, the speed, and the situation. I don't use it on hills, or coming down from hills, at lower speeds or in any kind of congestion, but I do use it on 50 MPH roads that are flat and where actually going that speed means I make all the lights in a 10 mile stretch green.
At the FEH Experience, Ford stated in their testing that on level ground, they could only match CC in their testing, but on hilly terrain, they always won.
Old May 11, 2008 | 10:20 AM
Our FEH's have cruise control???
Old May 11, 2008 | 02:43 PM
AA2070's Avatar
It's on the opposite side of the steering wheel from where the audio controls should be
Old May 11, 2008 | 07:19 PM
rmcmast's Avatar
I was heading into 15mph headwind in the Missouri River flood plane today (very flat) and decided to cruise at 50-55 and couldn't find the darn thing. Looked on both levers on the side of the steering wheel before I remembered the buttons on the steering wheel!
-- Rick
Old May 12, 2008 | 10:59 AM
I was just trying to walk uphill on a less than 10% slope into a 30 MPH headwind, and I could barely move. I don't know how our cars do as well as they do at 75 MPH.
The wind resistance is impressive.
Old May 12, 2008 | 12:06 PM
tcampb01's Avatar
Ford commented on this at the "experience" event in Dearborn. Basically the cruise control is probably better than most drivers at milking the best fuel economy on flat land.
However... the cruise control can't "anticipate" what's ahead and driver's can. On hilly terrain, drivers can take advantage of gravity on the downhill slopes to accelerate (so it doesn't really take much fuel to accelerate), then ease off the pedal on the upslope and let the momentum carry you back up the next hill. Cruise control wont do that. On hilly terrain a driver who knows how to milk it can do much better than cruise control. On flat terrain the cruise control will beat most drivers for milking fuel economy.
