"Stop Safely Now"
Old Sep 20, 2021 | 02:03 PM
  #401
stu132u's Avatar
Default Re: "Stop Safely Now"
2011 Ford Escape Hybrid w/"Stop safely now" and engine complete shutdown. The ford threw the four Codes: P0562 (System Voltage Low) P1000 (OBD System Readiness Tet Not Complete) P1A10 (Hybrid Powertrain Control Module Battery Disabled) and P1A1B (Brake System Control Module- Forced Engine Running) Vehicle shutdown and towed to the house. Three days prior, the AC went out on the Escape on a road trip to South FL. Could there be a tie into the AC failure? Looking for a specialist in the Orlando, FL area for help OR any assistance here on the forum would be appreciated.
Old Sep 21, 2021 | 07:25 AM
  #402
stu132u's Avatar
Newby here: I have a 2011 Ford Escape Hybrid and I had the wrench show up last Tuesday on a multi-hour round trip to West Palm Beach. First, the AC stopped working on the initial leg. The compressor (or something) was making a rattling noise, and now no longer turns on. IT wa time for an oil change and after that the wrench on the dash disappeared, but the AC still didn't work (one has nothing to do w/the other). Then on Friday, the SSN appeared and then shut down. Flatbed the vehicle to the house, and used an OBD-2 to attempt to get a diagnosis. The front tank for the coolant was almost empty; I've refilled it, just in case. The noise that I heard when engaging the AC have now stopped; possible compressor failure is suspected. Four codes showed:
  1. P0562 - System Voltage Low
  2. P1000 - OBD System Readiness Test Not Complete
  3. P1A10 - Hybrid Powertrain Control Module Battery Disabled
  4. P1A1B - Brake System Control Module - Forced Engine Running.
After erasing w/the OBD-2, replacing the 12V battery the new codes now show:
  1. P1000 - System Readiness Test Not Complete
  2. P1A10 - Hybrid Powertrain Control Module Battery Disabled
Engine will not start still showing SSN and the dreaded red triangle is lit. Also, the car w/the lock at the bottom left of the dash screen is constantly flashing. This is my work vehicle w/289k miles; maybe it's time to retire it, BUT I've seen NYC Taxi and others go 500k miles. I suspect the AC has a lot of to do with this, AND I'm concerned about the MECS pump. ANY help is appreciated; My work has me traveling all over the U.S. so I need help. Seems there's a few people who have experienced similar issues; those who are well-versed with these issues - Please help in trying to diagnose and develop a parts list to return the Escape Hybrid back on the road. Thanks in advance.
Stuart
stu132u@gmail.com
407-718-1787, mobile
Old Sep 23, 2021 | 06:20 AM
  #403
Plain OBD2 readers can't pick up many FEH codes. Recommend you get Forscan. You don't have the whole picture yet.
You shouldn't expect taxi miles unless you're operating and maintaining it as a taxi. Since you're averaging <30K miles/year, it's safe to assume you're not driving it as a taxi.
Inop A/C means your battery is getting little to no cooling. The 2011 is already compromised because they removed the rear evap dedicated to the battery. It's possible you have battery codes related to cooling.
tsumeone
Aug 27, 2014 02:46 PM
liegev
Nov 21, 2009 06:48 AM
08hybridok
Apr 11, 2009 02:37 PM
Escape_from_Hanover
Dec 16, 2008 05:11 PM
