SSN on cold engine
Old Feb 26, 2013 | 05:15 PM
Billyk24's Avatar
Default Re: SSN on cold engine
Originally Posted by Jolver
Had the codes read and they wanted to replace hv harness and reprogram bcm for $835. $35 parts and $800 labor. Since the harness had been replaced once already they agreed to just reprogram the bcm. One week later and several cold mornings with no problems.
There was a September 2007 service recall for the hybrid battery harness which was replaced at no charge. This work required the hybrid battery to be removed from the vehicle and there are photos on this site documenting this. Not sure why your bcm went bad?
Old Feb 27, 2013 | 04:05 AM
Jolver's Avatar
I'm not sure either. It had the harness work done on it already which is why they just reprogrammed the bcm instead if replacing harness too. I believe the program you mentioned expired in 2009.
AtomicAD
Jul 25, 2014 04:35 PM
Brandon Williams
Nov 2, 2012 11:18 AM
phenderson
Jan 19, 2009 10:13 AM
goldenbob
Dec 7, 2006 08:36 AM
JOE540CI
Nov 20, 2006 09:31 PM
