SJB Smart Junction Box_ Tire Sensor Failed
Old Nov 24, 2013 | 12:20 PM
el_pablo's Avatar
Default Re: SJB Smart Junction Box_ Tire Sensor Failed
Is there a specific model number for each Escape variation (Hybrid, 4wd, 2wd, tribute,...)? Or it is the same for all?
Old Nov 24, 2013 | 12:49 PM
el_pablo's Avatar
Could the part number be also : 6L8T14B476BG?
Old Nov 25, 2013 | 07:48 AM
GatorJ's Avatar
Click on the eBay link I posted above. The seller invites you to send them your VIN so they can confirm that it is the correct number PRIOR to making a purchase. The seller obviously has access to the same database system the Ford parts department uses.
Old Nov 25, 2013 | 04:09 PM
hc45's Avatar
Originally Posted by GatorJ
Pretty sure it's
6L8Z-15604-FB
http://www.ebay.com/itm/BRAND-NEW-OE...9da395&vxp=mtr
You can email that eBay seller your VIN and they will confirm the correct part number for you.
Thank you so much... I hope to solve all the trouble now... There is one and another one....
Have a good night.
H.
Old Nov 26, 2013 | 05:11 AM
wptski's Avatar
Imported from Detroit
The SJB is shown to be behind the interior fuse panel or maybe the fuse is attached to it, not sure. I've had the top on the console off on a FE and I assume that the FEH is similar in that respect. There isn't much room in there and would require removing the side panels, storage area, etc. Not sure how easy that'll be with the seats in the way.
Even after that, I "believe" the SBJ will have to be programmed and you can't do that yourself. If you did manage to replace it yourself, will a new SJB allow the vehicle to be started and driven??
Old Dec 5, 2013 | 10:36 AM
hc45's Avatar
Pretty sure it's
6L8Z-15604-FB
Now i'm very very confused.... Here are the 2 answers :
The part # you need is 6L8Z-15604-AB found here: http://www.ebay.com/itm/NEW-OEM-KEYLESS-ENTRY-ALARM-315-MHZ-JUNCTION-BOX-2006-ESCAPE-ESCAPE-HYBRID-/231022928542?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item35ca0a229eKind Regards,
Dear tasca_tpc,
Thank you Hector for your answer... But to be sure.. muy problem is with Tire Sensor Fault signt that is showing that not the alarm...
Thank you.
Unfortunately we wouldnt be able to help with any diagnostics, you would need to get it checked by a certified mechanic or your local Ford dealer to pinpoint the exact problem.
Kind Regards,
Hector
Now really don't know what to think... any suggestion ?
Old Dec 6, 2013 | 03:20 AM
GatorJ's Avatar
The part # you need is 6L8Z-15604-AB found here: New Keyless Entry Alarm 315 MHz Junction Box 2006 Escape Escape Hybrid | eBay
Kind Regards,
Dear tasca_tpc,
Thank you.
Kind Regards,
Hector
I don't believe you asked the seller the correct question. You can't expect them to accurately diagnose your problem through an email. IF you determined your SJB is at fault, you should only ask them if the one they were selling fits your vehicle or not.
Old Dec 6, 2013 | 08:39 AM
FjordHybrid's Avatar
Kind Regards,
Dear tasca_tpc,
Thank you.
Kind Regards,
Hector
Just different names for the same thing. The security stuff is inside the smart junction box so I guess they call it a security module now.
Old Dec 6, 2013 | 01:41 PM
hc45's Avatar
Thank you so much.. So there is only one SJM... Ok i will buy these one. ;
Regards
Hem
Old Dec 6, 2013 | 04:30 PM
xspirit's Avatar
As for the tpms sensors in the rims, my mechanic just replaced all the Ford ones with EZ-sensors made by Schrader. They cost 1/4 as much as the Ford ones, and they can clone/copy the identification information off any other sensor such as the Ford ones. So if you have two sets of rims, they can be set up so you can swap sets without tpms problems.
Curated Content Editor
Jul 11, 2014 11:01 AM
JohnVirginia
Aug 1, 2011 05:58 AM
tim1234
Jun 7, 2011 06:42 PM
mikesus
Feb 4, 2007 11:47 PM
dialogue
Aug 12, 2006 02:29 PM
