Service Power Steering module gone bad
Old Jan 16, 2009 | 11:08 AM
suboptimal's Avatar
Default Re: Service Power Steering module gone bad
Dealer just called. At first they got a "C1778" trouble code, but after clearing it and restarting, everything worked fine. The code apparently indicates a problem with the EPS controller, a $600+ repair (no longer under warranty). I found a related discussion over at Edmunds.com Town Hall (http://townhall-talk.edmunds.com/direct/view/.f0fb471), but nothing especially helpful. Now we have to decide if it's worth the money to fix a one-time/possibly intermittent problem. The dealership has no further information or recommendation.
I don't really understand the "let it warm up" recommendation. Our car had been driven about 30 miles before we stopped for breakfast, and was off for only 5 or 10 minutes before restarting the problem occurring, so the car's systems were probably still warm. If cold was the problem, I would have thought that the problem would have occurred at the first start-up of the morning.
Hope you get a better answer from your friend at Ford.
Old Jan 16, 2009 | 12:39 PM
campton1's Avatar
This is fantastic news (not the $600 part, but the code at least). I'll call my dealer and relay the information. There is an earlier post in this list about someone with a 2007 vehicle who had some sort of "module" replaced.
I agree on the "let it warm up" piece. Our car had gone about 5 miles, it sat for 5 min, then was started up again.
Old Jun 10, 2013 | 11:22 AM
dawey1's Avatar
Does anybody have a write up on how to change the electric power steering control module or how to test it?
Just curious as I'm having the intermittent wrench and service power steering warning.
Thanks in advance.
Old Jun 10, 2013 | 04:04 PM
wptski's Avatar
Imported from Detroit
Thanks in advance.
There isn't one as the EPS isn't serviceable just replaced as an assembly. Didn't really think that the 2007MY had EPS.
Old Jun 10, 2013 | 04:11 PM
GaryG's Avatar
You got to be kidding me Bill, EPS came on the first '05 FEH!
Gary
Old Jun 10, 2013 | 07:14 PM
wptski's Avatar
Gary
I'm serious, I'm not a know it all!
Old Jun 18, 2013 | 09:11 AM
dawey1's Avatar
Is there a write up floating around that guides one through the removal and installation of the EPAS unit.
There has to be something out there. This truck has been out since 2005.
Does anyone have access to a service manual/shop manual for the 2007 FEH?
Dropping close to $1500 to replace the EPAS assembly at the dealer is not really feasible right now.
Thanks in advance.
Old Jun 20, 2013 | 04:53 AM
wptski's Avatar
Thanks in advance.
A Ford Workshop Manual is what states that you can't service the unit and you must replace the entire assembly.
Old Dec 4, 2013 | 11:18 AM
tothemax's Avatar
I have had the same issue. Here's my post on Escape city which returned no results. It looks exactly what was described above.
This is the second time this has happened to me. The first time was on a hard brake and swerve to dodge a car that stopped short ahead of me. that was about 6 months ago. Yesterday I was slowly pulling into a a traffic circle and the power steering just stopped, manual steering still worked OK but difficult to turn. I stopped the motor and restarted and it seemed to be fine. With a road trip coming this week I thought I would post to see if anyone has experienced this and if it is serious.
After my MECS pump issue and the $600 savings by doing it myself I'm a little gunshy of taking it to the dealer first.
Will appreciate any information,
------ No replies or comments there...
It has been a few weeks and hasn't happened since. The first time it occurred I did a hard stop and turn to avoid a road hazard. This last time there was no warning, going slowly around a downtown traffic circle. The steering continued to work (like a tank) and I was able to pull over and restart the motor. That seemed to resolve it. Does this mean that this will be a continuing issue or are these random occurrences under special conditions (overheated electric steering control)? We have 138K miles... and I'm hoping this isn't an omen.
We've been very pleased with this vehicle to date - the MECS pump experience was a lesson that the dealer option needs to be closely considered before letting them do the work.
Will appreciate any feedback,
Max
Old Dec 4, 2013 | 03:59 PM
Billyk24's Avatar
Mine did go bad and did not return to normal. I had the local dealership replace the bad unit with a brand new one and all is good. Posted this information elsewhere.
