Scanguage coding and fuel pump pulse width
Has anyone gotten the Fuel Pump Pluse Width coding to work?
This is for Bank 1
TXD= C410F1221141
RXF= 046205110641
RXD=3010
MTH= 000200010000
coded FP1
Does one have to have Bank 2 coded and in operation for these readings to exist?
This is for Bank 1
TXD= C410F1221141
RXF= 046205110641
RXD=3010
MTH= 000200010000
coded FP1
Oh, I see, you used the FORD PWM! I think that you have to use FORD CAN.
I tried the Ford CAN values without any luck.
I also tried to obtain the air/fuel ratio with these numbers:
TXD: 616af10114
RXF: 044145140000
RXD: 2808
Mth: FFFD00020640 or FFFE0001066B
NAM: A/F
but I was unsuccessful. I obtained the A/F numbers from: www.cleanmpg.com/forums/showthread.php?t=18601
I do not know if the cleanmpg numbers were referring the Ford Escape Hybrid or another vehicle.
TXD: 616af10114
RXF: 044145140000
RXD: 2808
NAM: A/F
Thank you for the reply. I got the Air Fuel ratio to display as shown below. The injector pulse width coding is still being researched.
I know diddly squat about coding the SG-II!
I sent CMD 221141 into the scanguage and received this:
I can't do anything more without feedback as I don't know "coding" for the scanguage either.
Billyk
May 23, 2010 12:49 PM
Billyk
Alternative Fuel Vehicles
Nov 27, 2008 07:28 PM
