ScanGauge Backlight Remains On
Old Feb 8, 2007 | 11:34 AM
econoline's Avatar
Default ScanGauge Backlight Remains On
My SGII never turns off the backlight, even with the key out and overnight. It's always illuminated the next morning and with a blank display.
Is this normal operation for the SGII?
Old Feb 8, 2007 | 01:08 PM
TeeSter's Avatar
Default Re: ScanGauge Backlight Remains On
Nope.... mine shuts off.
Old Feb 8, 2007 | 02:01 PM
GaryG's Avatar
Make sure you have selected Hybrid under the Type Of Fuel setting. Other than that, mine comes on sometimes when the PCM wakes up or if you have a dome light on or door ajar.
GaryG
Old Feb 8, 2007 | 08:15 PM
econoline's Avatar
GaryG
When I park for the night the backlight does go off. But if I check again later tonight or in the morning, it's likely the backlight will be on. I did ask Ron at SG about this and sounds like it occurs sometimes due to activity on the data bus. He immediately offered to exchange it but it's not a real problem, I was just curious.
Ron did comment that the SG may eventually be capable of reading the battery SoC, sounds like they are working on that.
Old Feb 8, 2007 | 11:46 PM
Yes. My backlight comes on and stays on if I ever open a door ( and get the brakes charging sounds ) or do anything else to "wake the car up" after the key has been removed for the night.
If I just park, and leave everything off in the car the whole time, the ScanGauge stays off the whole time as well.
-John
Curated Content Editor
Feb 20, 2014 05:00 AM
Dec 27, 2013 07:20 AM
Jun 13, 2013 05:30 PM
pagemap
Mar 19, 2008 01:03 PM
Brady
Jul 18, 2007 11:03 PM
