Scan Guage II
Old Jun 20, 2020 | 01:38 PM
fglaustin's Avatar
Default Scan Guage II
Can the ScanGuage II program the Smart Juction Box (SJB) in order to turn off the DRL?
Old Jun 21, 2020 | 08:38 AM
fglaustin's Avatar
Default Re: Scan Guage II
i have written linear logic in mesa arizona - hope to have an answer some time this week
Old Jun 22, 2020 | 12:52 PM
fglaustin's Avatar
reply from scanguage was a negative
Old Jun 22, 2020 | 01:00 PM
econoline's Avatar
Did you search the forum for DRL? I'm probably wrong, but I seem to recall a way of turning off DRL with a sequence of key turns and dashboard controls. Worst case, the dealer can certainly do it, but probably $100 charge.
Old Jun 27, 2020 | 10:33 AM
fglaustin's Avatar
i think that sequence you are referring to turns off the seat belt warning chime (or one of something like that).
in an f series foruim it is mentioned that for 07 and older, there is a resistor block near the left side headlight and one only needs to disconnect
and the drl are off (i suspect it is the same for the escape - not for sure though).
dealer can do it (might be a high fee) but i have read on older forums where the dealer turned it on for free - maybe be for good will as a safety feature
and/or someone has an insider that will help a person out.
Forscan can do it - good threads on that forum about it - but i think that it is high dollar for forscan.
Old Jun 28, 2020 | 07:32 AM
Rex B's Avatar
Forscan for Windows is free. It's also the most useful version IMO
Old Jun 28, 2020 | 09:01 AM
+1,000
Scangauge is antiquated in this day and age. With $20 bluetooth/wi-fi OBDII readers and free/cheap apps, they are essentially an over-priced/underperforming product. I have one. I plugged it in once. It's in a box somewhere now because I have so many other cheap tools that are more effective and easier to setup.
Old Jun 29, 2020 | 05:13 PM
fglaustin's Avatar
thanxs Steve for the insight; i need a 12 volt for my FEH so i am not driving now (but was about 3 days ago);
but to get to my point, i thought that owners (FEH) were using the scanGuage as a tool for monitoring the coolant temperature;
it does not have a coolant temperature guage so ScanGuage can be set up for that purpose.
Do you (and anyone else reading this) agree?
Old Jun 29, 2020 | 05:15 PM
fglaustin's Avatar
thanxs Rex for the reply - looks like that is on the "to do" list;
got a few projects in front if it though.
Old Jul 1, 2020 | 04:29 AM
fglaustin's Avatar
this is from the year 06 and i think it is the toyota forum:
"For me, the reason for purchase was to be able to have a real-time display of various sensor readings, so that I can see what's going on with the ICE. One can display, amongst other items, ICE rpm, ICE % load, water temperature, fuel usage per hour rather than per distance, etc. This has helped me understand what the ICE is doing at different times. The fuel economy readout spans a much greater range than the dashboard display."
laloland
Feb 9, 2013 05:33 AM
kklein
Nov 19, 2010 09:47 AM
miketeri
Oct 5, 2008 10:18 PM
Islander
May 4, 2007 04:16 PM
