Rust Protection and First Oil Change
Old Jun 1, 2008 | 02:41 PM
Sphinx88's Avatar
Default Rust Protection and First Oil Change
I am in Canada and in winter there will be lots of salt on street to remove the snow. Is it the case that the truck can be more easily rusted? Did you buy the dealer life time rust treatment or you do it year by year? The eletrical eletrode method is better or grease rust protection is better? If you select the electrical method, does it require more gas from 12 V battery?
I heard after the breaking period it is better to change oil. Do you change your first oil at 1000 mile or wait untill 10,000 mile for the first oil change? Do you use synthetic oil or just normal ones? Do you stick on Ford's recommanded frequency (every 10,000 mile) or more frequent?
Here are some pictures of my new 2008 Ford Escape Hybrid 4WD:
Thanks!
Below is an old image, I already installed a 4WD sign just above the hybrid sign.... )
Old Jun 1, 2008 | 02:55 PM
Sphinx88's Avatar
Default Re: Rust Protection and First Oil Change
I just added a 4WD sign above the Hybrid Sign. Would like to add additional two "Hybrid" signs at sides of the truck but it is very expensive, $70....
Old Jun 1, 2008 | 04:23 PM
Rust Protection--if this is what you want, go with an aftermarket vendor such as Ziebart with annual touchup treatements. I would skip the dealer installation. This rust protection question also requires one to ask themselves how long do they keep their vehicle?
First Oil Change---I would wait until 4-5 thousand miles (8K in metric) before switching over to full synthetic.
Old Jun 1, 2008 | 06:53 PM
Sphinx88's Avatar
Thank you Billyk, I would like to keep it for 10 years if possible.
Old Jun 1, 2008 | 07:16 PM
bmisf's Avatar
Hi Sphinx - nice!
Where did you get the 4WD badge? I'd be interested in one for my 4WD MMH, so that I don't have to explain at chain control stops in the mountains.
Old Jun 1, 2008 | 07:54 PM
Sphinx88's Avatar
Just at dealer, call the parts department and order, about $15. After getting it, dry clean the surface and stick it on when temperature > 21 Celsius.
Old Jun 2, 2008 | 11:13 AM
stevedebi's Avatar
Where did you get the trash bin?
Old Jun 2, 2008 | 11:21 AM
bmisf's Avatar
I can answer that one - in the 2008 model, it's one of the inserts from the between-the-seats console; you can remove it from there and hang it off of the rear of the console. There's also a smaller insert that slides into a "bracket" on the side of the dash center console in the passenger footwell.
Old Jun 2, 2008 | 11:22 AM
MyPart's Avatar
That's the tray from inside the console, just turned around, facing backwards
Old Jun 2, 2008 | 12:03 PM
stevedebi's Avatar
Thanks to all for pointing out where it came from. I took mine out and put it back there as well.
Then there was an eye opener there is a CAVERN inside the console! It is actually an "L" shaped hole that goes much deeper than the insert. So I think the area is more useful with the insert removed anyway.
