Ruh-Roh "Service Soon" and No Engine Power...
Old Aug 31, 2007 | 09:28 AM
DesertDog's Avatar
Default Re: Ruh-Roh "Service Soon" and No Engine Power...
Originally Posted by Billyk
Carl, I did hit the scan button but no trouble codes were revealed. I can't remember exactly what or how I did it, but remember being able to find a location where I could input the 22490B and then there was a variety of stuff like cml, abbreviations that I had no ideal what they meant and then the send button/command. Something was sent into the engine control portion of my vehicle and caused the regenerative braking to go out and loss of power. Thank goodness I remember reading some thread in here that stated to cut the engine. Wait something like 10 seconds and try starting it again. I haven't had a problem since.
Sending the 22490B CMND will not cause any problems. You are just requesting information from the TCM. Any problems afterward are just coincidence.
With my beta ScanGauge firmware, I am sending that and many other commands constantly with no problems.
Old Sep 1, 2007 | 03:07 PM
c0ugar69's Avatar
My 2005 did the same thing, got on freeway, no acceleration, wrench light came on, engine should have been on as i had the a/c on max and the car just got slower and slower. dealer found a bad electronic throttle body and they replace the small 12v battery too. havent had anyproblems since. I figure maybe the throttle body was telling the computer that i wasnt going fast enough for the ice so it shut off and we were running on just the electric till the battery went dead. A/c may have been on econo mode, cant remember. but i did not get any codes, neither did the dealer, he had to drive it for a couple days till it did it on him. hope this helps
Old Oct 6, 2007 | 06:24 AM
EOppie's Avatar
HEV's are your friend
This has happened a few other times since the last post...and I was hoping it was in relation to the service bulletian, however I have yet to recieve a card in the mail...
Old Oct 6, 2007 | 01:16 PM
KenG's Avatar
I think the mismatch of throttle and engine power is one key input. My 08 had a foreign object (rubber plug) from the factory that jammed the throttle plate partially closed. The wrench light came on and it seemed to default to about 50 mph max.
EOppie
Apr 23, 2019 06:21 AM
lloyd123
15
Jul 15, 2018 11:30 AM
RiverRat37
Jul 3, 2015 02:21 PM
jworth
May 10, 2010 12:54 PM
Escape_from_Hanover
May 8, 2009 09:11 AM
