RPM stuck at 2000 with A/C?
Old Jul 6, 2008 | 10:18 AM
  #31
wwest's Avatar
Default Re: RPM stuck at 2000 with A/C?
Originally Posted by stevedebi
If I read your suggestion correctly, you are suggesting TWO compressors, one for when the ICE is running and one for electric only? Interesting, though it would be expensive to have two compressors.
It is the people who wish to change Ford's careful design
I wish, truly, that we could see Ford's careful design prior to beancounter "optimization".
who are "grasping at straws", as you put it. I am telling them that it is not that simple.
I am simply pointing out that a hybrid system is far more complex, and the parts interact more closely, than a conventional drivetrain.
Ford certainly knew they could go to an electric compressor, yet they did not, even with the 2009 (so far as we know). So the car we bought is designed to use a mechanical compressor. That means that the computers (especially) are designed to compensate for the engine driving the compressor, NOT for an electrical compressor. This particular thread is listing an interesting part of the programming, namely that at temperatures above around 98F, the CPU directs the engine to add around 500 RPM when the A/C is engaged.
As a software engineer, it irks me that people think they can simply swap stuff out and have the vehicle simply work the same as before.
Maybe you should spend a bit more time with some hardware design engineers.
How many software engineers does it take to change out a light bulb....??
None, that's a hardware engineering task...
These vehicles are very precisely computerized, and any such change would require adjustments to the CPU programming -
So, you're saying that were I to swap out ALL of the incandescent light bulbs, interior, stop/tail/turn/street/parking, for much more efficient LEDs (10:1), use 35W hi/lo HIDs for headlights, the software might need to be changed to compensate for the reduced electrical load...??
for the engine, and possibly for other components, to compensate for the ELECTRIC compressor - which draws FAR more AMPS than the factory sound system.
I wouldn't be so quick to jump to that conclusion were I you. An electrically driven compressor, driven via an energy efficient variable frequency AC inverter as in the Prius/RXh/HH, can be run, operated, at whatever pumping rate just barely meets the cooling needs of the passenger cabin. That allows the evaporator outflow "target" temperature to be set just a few degrees below your temperature setpoint.
Whereas an engine belt driven system as currently used in the FEH/MMH series is of the "bang-bang" on/off cycling type(***) and with an UNLIMITED refrigerant metering system, target temperature of the evaporator outflow is ALWAYS <35F. That's why the FEH/MMH still uses the reheat/remix air temperature regulation method, giving two reasons why the ICE must be run with A/C on.
*** Exception: many newer AC systems use a variable displacement, "swash plate" A/C compressor so the engine belt driven compressor pumping rate can be adjusted independently of engine RPM. Sort of an individual CVT for the A/C compressor.
No, not two compressors, but a tandem drive arrangement, an electric clutch for the "traditional" engine driven method, and an embedded permanent magnet synchronous A/C motor. Or maybe an HSD "like" CVT to drive the A/C compressor. Planetary gearset would allow primary drive power, (times when HIGH refrigerant pumping capacity is REQUIRED) from the ICE or if the ICE must be run for other reasons, backup with AC drive if not, an infinitely variable refrigerant pumping rate.
Sad to have to say this, but for too many years now Ford's design approach now gives too much weight to the "beancounter" portion of the overall equation.
As a result I would wager that one could buy a portable heat pump unit (McLendons, $350, 13,500 BTU, dual intake/exhaust hoses) run it with a MSW DC-AC inverter, and improve FEH/MMH winter & summer FE by as much as 10%
Not by any means proposing that the FE "return" would justify the purchase cost.
Take out the beancounter portion of the equation and the FEH/MMH would have had VSC at inception.
Old Jul 6, 2008 | 10:52 AM
  #32
wwest's Avatar
Just so you understand.
Driving the A/C compressor through a Toyota HSD type/design CVT using the ICE and/or variable frequency LOW POWER electric drive motor would allow/require the use of the ICE for quick cool down of a HOT passenger cabin but then the low power, lower power electric drive mode could be used alone to sustain the passenger cabin at the comfort setpoint.
A completely, continuously, variable pumping rate of refrigerant could be used to eliminate the reheat/remix mode so no HOT engine coolant would be required to "regulate" (moderate) the system air outflow temperature.
The result might be an even more efficient A/C system than that using only a HIGH power capable A/C drive.
Old Jul 7, 2008 | 10:54 AM
  #33
stevedebi's Avatar
Originally Posted by wwest
I'm not saying, nor proposing, that there will not be times that the A/C is the EXCLUSIVE reason for seemingly inordinantly high ICE RPMs, just that sometimes you might see a high rate for other reasons or combined reasons.
Well, this is the only unexpected high RPM that I've seen. Other times that I've observed higher RPM there was a pretty obvious reason (higher engine load, up hill, etc).
IMAhybrid
Apr 16, 2008 03:36 PM
kris
Mar 5, 2007 05:15 AM
SilverToyCam
Jul 21, 2006 03:22 PM
jope
Jun 9, 2006 08:40 AM
Jason
Jan 16, 2004 05:40 AM
