Replacing 12v Battery - procedure?
Old Mar 8, 2018 | 09:27 PM
panamapat's Avatar
Default Replacing 12v Battery - procedure?
The existing 12v battery in my 2012 is only 3 years old, but is weak (barely passes a load test). I'd like to replace it, but is there a special procedure required?
On regular vehicles, after battery is replaced I may have to reset radio programs and it may take a few drives for the engine control unit to relearn the fuel trims.
But on the FEH, is there a special procedure once battery is pulled and replaced? Any practical experience you might share on the FEH?
Many thanks.
Pat
Old Mar 8, 2018 | 09:30 PM
Default Re: Replacing 12v Battery - procedure?
Can't say it's any different than any other vehicle. I prefer to let it idle for a few minutes after replacing the battery, so it can assess the HV battery state of charge at more moderate currents.
Old Mar 9, 2018 | 04:56 AM
Rex B's Avatar
On most cars you can preserve existing settings by connecting 12V to the dash power outlet (Cigar lighter socket). You can use a jumper battery with appropriate cable. You can also buy a tool that uses a 9V battery. As long as the voltage stays above a certain value the settings and memory will be preserved while you swap the battery. All shops use a version of this.
Old Mar 9, 2018 | 09:40 AM
panamapat's Avatar
Thanks all for help. Will advise if I run into any unexpected issues.
Pat
Old Mar 11, 2018 | 03:34 PM
panamapat's Avatar
Per RexB suggestion, I connected a 12v to the vehicle while swapping out the battery and all settings were preserved.
Thanks for suggestion.
Pat
ukrkoz
Jan 24, 2016 08:27 AM
Bill Winney
Nov 5, 2015 12:33 PM
schmidtj
Feb 17, 2013 07:03 PM
mppkll
Sep 25, 2008 03:07 PM
lifespeed
Sep 3, 2008 06:23 PM
