Recent large drop in MPG... causes?
Old Jan 3, 2007 | 12:29 PM
sirfergy's Avatar
Default Recent large drop in MPG... causes?
I've been getting 29ish MPG this winter, but I just took a 10 day vacation and am now getting 26ish MPG. Is there anything that could cause this?
I've had my FEH since June 06 and during summer I was getting 32ish and expected getting 29ish for winter time. I am very surprised by the 26ish I'm getting now though.
Old Jan 3, 2007 | 12:30 PM
jmorton10's Avatar
Default Re: Recent large drop in MPG... causes?
cold weather will do that.
~John
Old Jan 3, 2007 | 12:31 PM
sirfergy's Avatar
When we had the super cold of 20s I still was getting better MPG. It's about 45 out right now.
Old Jan 3, 2007 | 12:50 PM
WaltPA's Avatar
If you were on the highway cruising, just using the ICE, that will use more gas. Plus, highway cruising typically adds a lot of miles into the MPG average calculation (all those highway miles were at that lower ICE only fuel consumption).
I know that when I went on a trip, my MPG average went down, and upon my return, it took about 2 weeks of regular driving to offset that.
Old Jan 3, 2007 | 01:29 PM
nash's Avatar
Did you have the defroster on all 10 days?
Old Jan 3, 2007 | 07:31 PM
Tim K's Avatar
Cold temps will do it, as will fuel with ethanol added. It could be that you used a blend that contained more ethanol than you are used to. The pumps can contain UP TO 10% ethanol....which means you might have been getting 5% in your area and 10% while on your trip.
Old Jan 4, 2007 | 12:10 PM
BadFrog's Avatar
Rabid Offroad Enthusiast
You might want to check your front end alignment (and possibly rear) or try rotating your tires. I recently had my front struts replaced, got a front end alignment, and rotated the tires. I picked up about 2 mpg which kind of suprised me. (I should have done them one at a time so I would know what had the most effect.)
I've got a 2" lift kit with 31x10.5" tires (which is why the stock struts wore out at 25,000 miles). I replaced them with Monroe® Sensa-Trac® struts, and the ride is far better then when the the stock struts were new.
Old Jan 14, 2007 | 10:55 AM
xpl0re's Avatar
After I've gone about 8,000 miles without an oil change, I seem to get a sudden drop in MPG. Getting an oil change bumps it up almost instantly.
Ford recommends every 10k, but I try to do it every 5k-ish for this reason.
sirfergy
Jan 31, 2011 10:17 AM
ShellyD
Sep 30, 2006 05:19 PM
