Rear differential must not hold 2.96 pints!
Old Jul 28, 2013 | 01:03 PM
TeddyB4x4's Avatar
Default Rear differential must not hold 2.96 pints!
Has anyone else noticed this?
I just had to pull the cover when all I could siphon was less than 1 quarts[it was nasty, too]...and there was no more in there...the fill plug had oil spilling out after I took it out-so I think it was full! gotta go get silicone and brakekleen, we'll see how much it takes to fill later
Old Jul 29, 2013 | 01:36 PM
TeddyB4x4's Avatar
Default Re: Rear differential must not hold 2.96 pints!
Saved trip to the store, cleaned with intake/carb spray and sealed with old tube silicone. thus , let dry a day.
1 pint must be trapped in front of the open differential. saw no way to drain. so much for clean new Mobile 1.
funny I could find no post on this after a pretty exhaustive search and didn't remember lockup(whatever), it's pretty tight under there on the ground
Old Jul 29, 2013 | 04:33 PM
wptski's Avatar
Imported from Detroit
Mobile 1???? The Mobile 1 site page doesn't list any of their products for your rear end. Look in your owner's manual for the correct lube to use before you fry it.
Old Jul 29, 2013 | 06:39 PM
TeddyB4x4's Avatar
75w-90 IS CLOSE ENOUGH FOR ME!!!!!!!!!!!!!!!!!!!!!!!!!!!
I bet it's better than Motorcraft or made for them
TeddyB4x4's Avatar
what about the Capacities I addressed?
Old Jul 30, 2013 | 05:35 AM
wptski's Avatar
I bet it's better than Motorcraft or made by them
It's your repair!
Old Jul 30, 2013 | 09:38 AM
TeddyB4x4's Avatar
Heath
Amsoil Synthetic Lubricants / Click here for more info!
Diesel Master
iTrader Score: 0 reviews
You're good. As mentioned, the grape juice is 75W-90. Just an FYI, a good synthetic 80W-90 meets the same specs as a 75. Ours does. We make an 80-90 to satisfy those who insist on having those numbers on the bottle, but it meets the specs of a 75-90
Again ; have you changed a rear end fluid like mine? Which is the subject of this post? my old, black oil was like 30w and now your trying to convince me it will break......
Old Jul 31, 2013 | 06:14 AM
wptski's Avatar
Heath
Diesel Master
No, I haven't changed the rear end fluid in any vehicle I ever owned. Now with this Unintelligent 4WD that engages every time you leave from a dead stop, it might need changing sometime. Since I don't even have 10K on my '09, I may never need to.
I'm not trying to convince of anything but to follow the specs listed in your owner's manual and use the proper lubricant. Does the lube have the Ford Spec listed in the Owner's Manual on its label?
raldin
Toyota Highlander Hybrid
Jun 27, 2017 08:11 AM
srivenkat
Feb 2, 2013 03:32 PM
mmrmnhrm
Feb 19, 2009 05:55 PM
noflash
Jul 10, 2008 08:07 AM
bajer
Dec 19, 2007 06:26 PM
