Rattle from Rear Hatch
Old May 8, 2010 | 02:19 PM
Cheeto's Avatar
Default Re: Rattle from Rear Hatch
Originally Posted by tas246
I had this same problem (or what seems to be the same problem)...
For me it was the glass on the rear end rattling where it hooks in. I ended up fixing it by wrapping the metal connector on the glass gate with a piece of electrical tape where it contacts the white latch. The problem immediately went away and hasn't returned since (~4 months).
Tom
THANKS! $0.10 of electric tape on the hook and latch just solved what several trips to the dealership could never resolve. They tried to tell me once that I just had to keep lubricating the rubber liner for the window, which of course did nothing for the squeaks and made my car smell like WD-40 for a week.
Old May 9, 2010 | 06:54 PM
bob95fxdl's Avatar
Glad your problem was simple.
I had a similar issue with my 06 FEH. However, mine turns out to be the little rubber baby buggy bumpers they put at the corners of the hatch window. One is missing and caused the rattle at the rear window. Now to find out how much the dealer will burn me for just one of those little things.
Speaking of burning, it turns out the dealer wants $100 to code one of the transponder keys these things all come with now. What a rip! I have two remotes, two transponder keys and two transponder key blanks, JIC.
Soes anyone have a better solution on getting keys cut and coded? Even Wally World won't cut them because of the transponder, in case they botch it up (even though the systems are now automated.
Any insight appreciated.
Bob
Old May 9, 2010 | 07:49 PM
econoline's Avatar
Bob
I bought the blank key/transponder from eBay and took them to Lowes to be cut. The blanks were somewhere around $12 plus $2 for cutting. The programming is done by you by following the instructions in the owner's manual. You insert the new key into the ignition and follow the programming steps.
Old May 10, 2010 | 03:46 PM
bob95fxdl's Avatar
Unfortunately, it isn't that easy any more. Since Lowe's, Home Depot and Wally World all use the same automated system to cut keys, they now refuse to cut them. Before cutting, they insert the key into a small socket in the drawer of their cutting unit. The socket has a sensor in it. If the light comes on, it indicates a transponder chip in the key head. They then state they are not allowed to cut them and they kets must be taken to the dealer, thus the up to $100 fee for dealer service. I agree, though, that I should be able to code the keys for the vehicle, they have to be cut first, so they'll work in the ignition switch. You've got to love Detroit!
Last edited by bob95fxdl; May 10, 2010 at 03:46 PM. Reason: Found error in formatting
Old May 10, 2010 | 04:11 PM
econoline's Avatar
That's a bummer. I'd try an independent locksmith or one of those key cutting kiosks before giving up. I can't imagine a small shop turning away business, and there's no legal issue here that I'm aware of. Keep us posted.
Old May 10, 2010 | 04:28 PM
08hybridok's Avatar
I can't remember where I had min cut now, I think I had to go to the dealer, but it was like $1 maybe $10 (I bought my key on ebay for like $20-30??) then I programmed it myself. You might find one of the old fashioned places can/will do it. I saw one in an Ace once, my local old fashioned feed store has one too.
Old May 11, 2010 | 10:15 AM
  #27
MyPart's Avatar
I bought my transponder key blanks from autotransponder.com and then took them to the dealer for cutting. I think the dealer charged me around $5-$10 to cut the key.
I did the programming myself following the guide that autotransponder.com included. It was a really simple process.
It's important to note that you must have two keys already programmed for your system to add another key. If you don't have two keys, you'll be forced to go to the dealer or a locksmith. I highly recommend having at least three keys programmed at all times so when you lose one, you can add a replacement without having to pay dearly at the dealership/locksmith.
Old Oct 7, 2010 | 08:21 AM
  #28
Escaping in my Ford's Avatar
Tommyball you saved my day! I was so annoyed by the rattle I though I would get rid of the Escape. Two 3" pieces of electrical tape one on the hatch rod and one on the glass latch and my problems are solved. Can't thank you enough.
Tim K
Aug 23, 2015 02:28 PM
JoeRemix
Aug 26, 2008 09:18 AM
Island Mariner
Feb 19, 2007 07:58 PM
spacebug
Honda Insight
Jul 7, 2006 05:35 AM
tigerhonaker
Dec 19, 2005 01:22 PM
