Questions on the power management display
Old Nov 13, 2007 | 11:16 AM
MrCrank's Avatar
Default Questions on the power management display
This is my first post here. I just got my FEH 08 last Tuesday. Three weeks ago I had no intention of buying a new car my beloved Jeep Cherokee started developing costly repairs and to make a long story short I ended up with this FEH. I wanted a hybrid and the Escape is the only one that is suited for (light) off-road use.
Anyway it is kind of funny how this car makes you obsessive over the mileage. So I've been watching the display on the nav system and reading the forums and came up with the following questions.
The display has four elements: the engine, the drive train, the electric motor, and the battery.
a. What does it mean when a line appears between the engine and the drive train? There is no direct mechanical coupling, so isn't it true that the only way the engine can drive the wheels is through the electric motor?
b. Shouldn't there be two electric motors -- actually motor-generators? One connected to the engine and the other connected to the drive train.
I have been searching for a schematic. I can find one for the Toyota Hybrid-Synergy-Drive (HSD) which is supposedly similar to the FEH's system, but I can't find one for the FEH. Anyone have some links?
Much thanks for any help.
Old Nov 13, 2007 | 11:38 AM
WaltPA's Avatar
Default Re: Questions on the power management display
There is indeed a direct mechanical coupling from the engine (what we call the "ICE") and the drive train. The ICE can drive the wheels. The electric motor can drive the wheels. Both can drive the wheels.
Well, the display diagram is a bit simplistic. The "arrow" from the electric motor symbol to the battery symbol, represents the generator. The "arrow" from the electric motor symbol to the drive train, represents the motor.
BTW, have you noticed that the thickness of the lines changes, representing the amount of electrical current moving?
Old Nov 13, 2007 | 12:52 PM
GaryG's Avatar
Here is a good article about how things work. There is also some real technical information. Look on page 9 to see how everything is connected.
http://www.motorcraftservice.com/vdi...DSM500_HEV.pdf
GaryG
Old Nov 13, 2007 | 01:16 PM
MrCrank's Avatar
Thanks for the quick replies and I see where I was getting confused.
There has been a lot of ink (pixels) spilled about the similarity between the FEH and the Toyota HSD what with the cross-licensing at all. But from this manual the systems do not seem that similar.
In HSD, the ICE is hooked up to a motor-generator and that's it. There is a second motor-generator that powers (or is powered by) the drive train. 4WD models have a 3rd motor-generator. In contrast the FEH seems to have one motor-generator with an assistant electric motor called a "traction motor." To get the job done that fancy CVT geargox is needed.
Interesting. I'll study the manual more.
Old Nov 13, 2007 | 03:27 PM
GaryG's Avatar
Here is another old but good bit of information MrCrank:
http://www.gulfcoastnews.com/RT2005FordEscapeHybrid.htm
GaryG
Old Nov 13, 2007 | 05:14 PM
Lurch's Avatar
I also traded in a 2001 Jeep Cherokee two weeks ago for an '08 FEH with little to no warning I went to test drive an FEH and the dealer had 4 sitting on the lot so I came home with the fully loaded AWD one of course
Old Nov 14, 2007 | 04:31 AM
WaltPA's Avatar
Yea, I sold off my 1999 Jeep Cherokee. I do, miss the higher luxury the Jeep had over the MMH... 6-way passenger seat, 2-heat level seats, tons of interior lights, 4WD active indicator, etc.
Old Nov 14, 2007 | 08:41 AM
Lurch's Avatar
Mine was a Cherokee (XJ) not a Grand Cherokee the only luxuries I had were the I6 engine and power windows Before that I had two Wranglers that didn't even have AC. The fully loaded FEH feels like a Mercedes to me.
Old Nov 14, 2007 | 10:04 AM
MrCrank's Avatar
Default FEH and M-Class
MThe fully loaded FEH feels like a Mercedes to me.
Now that you mention it, has anyone else noticed the similarity of the body style of the 2008 FEH and the Mercedes M-class? Anyone have any idea which influenced the other?
As for value, there is no question the FEH 2008 is a better value than the M-class, which would have some more doo-dads (like garage door opener and whatever) but $10K-12K more. And not a hybrid.
CHARGED EVs
General EV Discussion
Dec 12, 2011 08:13 AM
xavipedro02
Government & Taxes
May 7, 2010 04:39 PM
scole01234
Apr 21, 2010 12:13 PM
davidb
Jan 2, 2009 03:12 PM
