Which parts are different for a PHEV ?
Old Jul 11, 2008 | 04:19 PM
vortextra's Avatar
Default Which parts are different for a PHEV ?
Aside from batteries and plug, which parts exactly would need to be changed.
Computer(software or hardware) ?
What else ?
What would the parts dept at Ford say if I tried to order the parts ?
Old Jul 11, 2008 | 04:48 PM
Scahpe's Avatar
Default Re: Which parts are different for a PHEV ?
The parts department will look at you and laugh their butts off! There are no Ford PHEV conversion parts available.
There are aftermarket companies that can provide this conversion for you (at a very high expense.. $20k+), but you have to realize this isn't a simple 'replace the parts' kind of thing.
You need a larger battery and extensive wiring modifications, and customer computer reprogramming to make it work.
Old Jul 12, 2008 | 08:15 AM
wwest's Avatar
What else ?
But look at what could be done...
Build your own PHEV, plug in to your home natural gas line, that is.
Buy a small single, swivel, wheel tag-a-long trailer and mount a ~6000 watt genset and a small CNG tank. Fill the CNG tank at home from your natural gas line using "PHILL".
Build a control system that fires up the genset ONLY when the hybrid battery is in need of charging and always run the genset at its most efficient level, FLAT OUT.
You might even consider converting the FEH/MMH ICE to CNG.
Old Jul 12, 2008 | 03:25 PM
stevedebi's Avatar
Or you could just shift to dilithium crystals, it would be more practical. While you are at it, issue to order to "beam me up".
Seriously, who wants to pull a trailer all the time, not to mention the extra weight and drag, plus any safety issues (got brakes on that trailer?)...
Old Jul 17, 2008 | 08:12 AM
Sascol's Avatar
You could install a flux capacitor. It's important to note that this requires 1.21 gigawatts of electrical power to engage and to become operational. Once engaged though, your travel options are virtually limitless.
http://www.uncrate.com/men/gear/misc...lux-capacitor/
Old Jul 17, 2008 | 11:57 AM
Talk is cheap. Do it and report back here.
Old Jul 25, 2008 | 06:09 PM
Scahpe's Avatar
Here's a real one you can buy and install yourself! It also comes with an AWESOME return policy:
http://kalecoauto.com/index.php?main...products_id=28
Old Jul 25, 2008 | 08:07 PM
vortextra's Avatar
threadjacked by flux capacitors
My god, what happened to my thread !!!!!???????????
Old Jul 25, 2008 | 08:10 PM
You should close this thread. There is no Ford PHEV Escape at this time for retail sale.
BOFH
Oct 28, 2008 09:53 AM
MortalWombat
Mar 29, 2008 05:00 PM
tedpark
Oct 3, 2006 09:17 PM
Orcrone
Jul 12, 2006 12:56 PM
bookwitch
Oct 20, 2005 09:30 AM
