Which one is the drain plug?
Old Jul 7, 2008 | 12:51 PM
nitramjr's Avatar
Default Re: Which one is the drain plug?
Originally Posted by Sphinx88
Bad news, I did not successfuly change my oil filter. I bought a wrong filter wrench..
Did you try removing the filter canister by hand? They aren't on too tight, you just have to overcome the friction of the o-ring. I've done about 16 changes between both of mine and have never had to use a filter wrench.
Try it....
Old Jul 7, 2008 | 01:32 PM
Sphinx88's Avatar
Try it....
O really, I am not a very strong person but I will have try, thanks for your idea!
Old Jul 7, 2008 | 04:34 PM
OT7's Avatar
OT7
Drain plug Gasket part number is F5TZ-6734-BA.
List price $6.78
Old Jul 7, 2008 | 08:49 PM
TeeSter's Avatar
List price $6.78
If you get the motocraft filter... it should come with BOTH o-rings you need for both the oil filter drain plug and for the housing.
They didn't at first, and you had to get them separately, but after a while they started including them... My dad was a parts manager at a ford dealership and used to order them separately and "stuff" the box with the o-rings (they are required to do it right)... then later he didnt' have to.
Old Jul 8, 2008 | 04:36 AM
OT7's Avatar
OT7
Part number is for OIL PAN drain plug gasket.
Old Jul 8, 2008 | 06:14 AM
TeeSter's Avatar
Hopefully you don't need to change that one often. Its only the other two that they recommend changing every time from what I've been told.
Old Jul 8, 2008 | 07:26 AM
Sphinx88's Avatar
I am confusing. The O-ring of the silver hexgon female plug at centre of filter cap is easy to find. Using a 6mm hexgon male wrench.
I did not find O-ring for the oil pan drain plug, but found something robber like under the cap of that stud. Maybe it is the gasket. That wrench should be a 13mm hexgon female socket.
I went to store again yesterday afternoon and replaced the #2, 15 sides polygon oil filter wrench with the #9, 14 sides polygon oil filter wrench. The #9 wrench is a little bit smaller than #2, too. I tried without lifting my FEH, it seems a little bit too tight.
Hopefully next time I should be able to unscrew the filter.
Old Jul 9, 2008 | 11:35 PM
I use a pair of channel lock pliers to take my canister lid on and off.
I put it on by hand, and tighten another 1/10 of a turn with the pliers.
The 14-sided cap seems to be an odd size to me too.
I could not find one locally ( town of 100,000 persons ) that fit right for mine.
Pliers type tool makes a perfect fit every time.
Old Jul 10, 2008 | 12:15 PM
Sphinx88's Avatar
Thanks! Next time I am thinking unscrew the filter cap first, (Not completely removed, just loosen it before I remove the oil pan drain plug). If ok then it is OK to change oil, otherwise I need to order a filter wrench before I drain all the oil.
So Last time I only changed the oil without changing the filter. Since now the oil is new, If I try to change the filter now without unplug the oil pan plug, but only remove the filter, how much oil I could lost?
My colleague told me I will just lost a little because the position of filter is much higher than the position of oil pan drain plug...
Old Jul 10, 2008 | 10:57 PM
leoashton's Avatar
I'd recommend draining the filter using its plug after draining the pan (less oil on the hand.) The filter wrench I purchased at AutoZone is perfect. (OEM Oil Filter "B" Cap Wrench, (25401) for $3.99.)
I'd argue that this vehicle has to be one of the easiest for non-mechanics, no jacks, couldn't be easier to get to.
