Oil Change Required
Old Apr 11, 2009 | 06:46 PM
julianwilso's Avatar
Default Oil Change Required
What tells the 2009 FEH that the oil HAS been changed? I changed it at 9860 and when it rolled past 10000, the message changed to oil change reqired.
Old Apr 11, 2009 | 09:52 PM
08hybridok's Avatar
Default Re: Oil Change Required
You must have used the wrong oil then, it's got sensors that knows when oil is nice & clean and new
Or cycle thru the dash menu and push (hold maybe) reset.
Old Apr 12, 2009 | 10:15 AM
MyPart's Avatar
Page 80 of the 2009 FEH Owners Guide:
Oil life
An oil change is required whenever indicated by the message center.
USE ONLY RECOMMENDED ENGINE OILS.
To reset the oil monitoring system to 100% after each oil change
(approximately 10,000 miles [16,000 km] or 12 months) perform the
following:
1. Press and release the SETUP
control to display “OIL LIFE =
XXX% HOLD RESET = NEW”.
2. Press and hold the RESET
control for two seconds and release.
Oil life is set to 100% and “OIL LIFE
SET TO 100%” is displayed.
3. While “OIL LIFE SET TO 100%”
is displayed, if a lower oil life start
value is desired, press and release the RESET control to reduce the start
value. Each press of the RESET control reduces the value by 10 %.
2009 Escape Hybrid (ehv)
Owners Guide, 1st Printing USA (fus) Driver Controls page- 80
Note: Oil life start value of 100% equals 10,000 miles [16,000 km] or
12 months. For example, setting oil life start value to 60% sets the oil
life start value to 6,000 miles (10,000 km) and 219 days.
lifespeed
Feb 10, 2012 08:25 PM
MarkT
Mar 26, 2009 12:07 PM
Orient Express
Dec 6, 2008 11:23 AM
leepark
Oct 28, 2008 11:37 AM
Mitaka
34
Jul 11, 2006 08:59 PM
