new Scanguage software available
Old Oct 25, 2007 | 06:15 AM
  #61
DesertDog's Avatar
Default Re: new Scanguage software available
Originally Posted by glennb
Brady -
Same here. Blank digits on the SoC....but most of the others are working. SC firmware updated and the service campaign was completed on my FEH........frustrating
Most of the others are working - are battery temp, module delta voltage, and max charge/discharge working? Also, you could try changing the update rate to SLOW or FAST to see if anything shows up for SoC. MORE> MORE> RATE> SLOW.
If there is anybody who can't see *any* of the battery xgauges, let me know. The AWD models have an extra computer, and it is possible the traction battery address is different. For 08's, I think the battery temp PID may have changed.
Here are a few more battery xgauges to try, but generally aren't very useful for everyday driving.
Positive Bus Leakage: (kohms)
TXD: 0745224907
RXF: 46285490607
RXD: 3010
MTH: 02711000000
Negative Bus Leakage: (kohms)
TXD: 0745224908
RXF: 46285490608
RXD: 3010
MTH: 02711000000
Battery Evaporator Temperature: (degrees F) Scaling MAY be off, but gives reasonable values
TXD: 074522995A
RXF: 4628599065A
RXD: 3008
MTH: 000500010000
Battery Maximum Temperature: (degrees F)
TXD: 0745224907
RXF: 46285490607
RXD: 3008
MTH: 0012001FE70
Old Oct 25, 2007 | 06:47 AM
  #62
There are ( IIRC ) 8 temperture sensors inside the battery pack, and one inside the air duct that may be the evaporator temperature you speak of.
So when you get a "Battery Temperature" number on the SG or on the car's green message center, I am guessing it is reporting the highest of the 8 sensors? But it could be an average of all eight. Do you have separate PID's for HV battery temp and HV battery Max. Temperature?
If so, which one matches what is displayed on the car's green screen when you enter test mode?
Old Oct 25, 2007 | 02:46 PM
  #63
econoline's Avatar
Got my SGII back today. Took only 1 week door to door for the upgrade. Now to see if I can get SoC to display.
Old Oct 25, 2007 | 04:27 PM
  #64
econoline's Avatar
I'm also getting an all blank display for SoC on my '07 AWD FEH. Tried changing the update rate as suggested but no difference. I also programmed TBV just to confirm my programming and it displayed as expected. I haven't tried any of the other xgauges, but SoC is really the only one I was interested in. Thanks for any help with this.
Update: In reviewing this thread it seems like the SoC isn't working for those of us with AWD, regardless of model year. Has anyone with AWD gotten SoC to display data?
Old Oct 25, 2007 | 08:03 PM
  #65
Brady's Avatar
I only tried the first four from the list you had in post #7. Here's how those came out:
SoC: blank display
TBV: working
BTM: blank display
TrR: working
Thanks for looking into this Carl.
Old Oct 25, 2007 | 08:06 PM
  #66
I have a 05 AWD and my SoC has worked perfectly from the start. I reprogramed my traction battery voltage and got a reading of 314. I then reprogramed my traction battery temperature and got something like 64 but lost my traction battery voltage reading. Hmm, is there a conflict in trying to get two readings at the same time from the traction battery?
Old Oct 25, 2007 | 08:35 PM
  #67
econoline's Avatar
Okay, well that disposes of my AWD conspiracy theory.
I also got TBV = 314. I'll try displaying both TBV and TBM simultaneously and see what happens. BTW, this might be a case where changing the update rate could have an effect. Were you using "normal"?
Update: I added TBM but it is blank and never displays any data. TBV continues to display correctly with or without TBM. Don't know what all this means yet.
Old Oct 25, 2007 | 08:57 PM
  #68
Yes. If you need a photo, I can post one.
Old Oct 25, 2007 | 09:16 PM
  #69
DesertDog's Avatar
There shouldn't be a problem having more than one battery PID displayed at a time. On my 05 FWD, I can display 4 different battery PIDs at the same time. There is one PID, 4907, that contains 4 different temperatures, and I can only display one at a time.
For those of you who can't get SoC to display, try all of the battery xgauges - those that have a TXD that starts with 074522****
If none of these work, then it is probably a computer address problem that may be able to be resolved.
Old Oct 25, 2007 | 09:29 PM
  #70
fm606713's Avatar
I have had traction battery temperature, voltage, and SOC on at the same time and individually without any problems. All are giving normal readings.
