Re: Nav system rebooting while driving
Originally Posted by GatorJ
(Post 145115)
I have the 2005 3v discs. I was not aware that the 2007 set had been released until I received a postcard yesterday, so I did not know to ask if the new version was tried or not and that information was not volunteered. As I understand it, the current theory is that it is an interference problem, not an issue with the discs.
Mine have been replaced and are both clean and in perfect condition.
(Post 145115)
I mean, how can a person be the official Ford expert on our Nav system, and not know? |
Originally Posted by WaltPA
(Post 145246)
Well, actually, my point was against the Ford field engineer. He/she should have know about the new map disks, and if at all competent, should have brought a set with them.
As I have stated a few times - it isn't a problem with the NAV system but RF (Radio Frequency) that are shutting down the system. It isn't a problem with the NAV disk and a bad read on them, because I have had the black-out many times at the same locations without the NAV disk running. So I would say it is a shielding problem that effects the entire radion/Nav system. Phillip |
(Post 145289)
The other places are random with no discernable pattern and are not repeatable.
Originally Posted by VietVet'67
(Post 145291)
(Post 145291)
As I have stated a few times - it isn't a problem with the NAV system but RF (Radio Frequency) that are shutting down the system. It isn't a problem with the NAV disk and a bad read on them, because I have had the black-out many times at the same locations without the NAV disk running. So I would say it is a shielding problem that effects the entire radion/Nav system. Phillip As far as I can tell the system tracks GPS at all times when a disk is in the system EVEN if the NAV button is not pressed and the MAP button is off as well. If someone wants me to justify that assumption I'll explain the observations that lead me to that conclusion. In any case if your disk were in the drive but you weren't "actively" using the GPS function, it would not matter if I'm right. The system would reboot at the same location when a spot on the disc was read in the background. |
Originally Posted by TeeSter
(Post 145296)
Does "without the NAV disk running" mean the NAV disk is NOT in the system AT ALL? Just making sure, its a bit ambiguous.
As far as I can tell the system tracks GPS at all times when a disk is in the system EVEN if the NAV button is not pressed and the MAP button is off as well. If someone wants me to justify that assumption I'll explain the observations that lead me to that conclusion. In any case if your disk were in the drive but you weren't "actively" using the GPS function, it would not matter if I'm right. The system would reboot at the same location when a spot on the disc was read in the background. 1: the system did NOT reboot. 2: the system did not display direction of travel. I still do not believe (nor does Ford) that it is a disc problem. |
(Post 145315)
I believe you are correct. I went home the "always" way this evening. Two things of note:
1: the system did NOT reboot. 2: the system did not display direction of travel. I still do not believe (nor does Ford) that it is a disc problem. My own suspicion (I'll explain why I THINK so) is that it is actually a disc problem even if the Ford tech doesn't think so (I'm not sure a tech could tell if it was or wasn't a disc issue). Not a scratched disk or dirty disk since yours are new! I'm wondering if there just happens to be a bad spot in the database on the old discs. I've had the same thing happen once on a disc I made with a CD-R recorder but not on the orginals. The effect is EXACTLY as you describe, a reboot in the same location every time. When I went back to my original discs it was fine. I'm wondering if I had an error on my CD-R version and that their might be an error in the ORIGINAL database version on the disc and location you are using. Incidentally.... #2) is the reason I'm pretty sure its navigating all the time when the disc is in. It seems to need that to keep track of direction. Also you'll find that if you leave the disc in all the time you have alot less problems with the initial "I'm drving in the middle of a field" issue alot of people describe because the system doesn't have to get an initial lock, its always tracking location then. Its somewhat hard to accept it would lock up over an external RF signal for me. I'm an EE and I've done some interference/susceptability tests on equipment before. Its possible but usually the RF signal has to be REALLY strong unless you've built a piece of crap, or that its on JUST the right frequency (ie at the receiver frequency)...I'm not aware of anything that shares the GPS spectrum, I suppose their MIGHT be... They use the things for guiding passenger airplanes these days... I know if I was the FCC I wouldn't be letting anyone share that frequency spectrum! |
