Re: Nav system rebooting while driving
Originally Posted by chrizis
(Post 132567)
My had the same issue only all the time constantly, but I fixed it by
-removing the disk -turnung the car off then on the the Nav system asked me to update new software have know Idea where if got it from -I click yes it updated rebotted It has worked fine since. |
I Was hopping it would work... mabey I pressed the right combo of buttons to make the nav unit do a reformat or reflash its memory so the the disk want inserted it reinstalled it software.. had anyone see info on a nav system reset?
(Post 132587)
Originally Posted by TeeSter
(Post 132597)
Which disk did you insert..... I thought the "firmware" was only on disk 1
What is the latest firmware version?
So after my post now my system wont go into that audio setup to cange balance , fade, bass, treble. For worked on it all day, and now are ordering a new one may be I will get lucky and get a touch screen I will post the detail after the repair job..... or even just an newer map disc a lot has changed from 04 to 07 :)
(Post 134636)
Update: My 06 just spent 9 days at the dealer in attempt to finally resolve this issue. Ford ultimately flew in a field engineer as nothing attempted worked. Three Escapes were driven along the same path of travel where my system always reboots and all did exactly the same thing. The repair order indicates that no fix is available, but that Ford is aware of the problem.
Originally Posted by GatorJ
(Post 145108)
Did the field engineer even think of bringing the new set? As was mentioned here, I am inclined to think that there is an occasional error in the actual data stored on the disks, and the Nav system gets so confused by it, it reboots itself as the only means it was given to recover from simply bad data. If that is true, then hopefully the 2007 disks don't have the same error; at least not in the exact same spot on the maps. |
I have the 2005 3v discs. I was not aware that the 2007 set had been released until I received a postcard yesterday, so I did not know to ask if the new version was tried or not and that information was not volunteered. As I understand it, the current theory is that it is an interference problem, not an issue with the discs.
