Nav system rebooting while driving
I have read here a couple of people who had problems with their Nav system going blank, and then rebooting back up, while they were driving.
I had this happen only once to me, and that was a few months ago. It was on a local road I rarely travel. Well, on Saturday, I was on that same road, and in just about the exact same spot, my Nav system went blank, and it then rebooted. :omg: I have no idea what could cause such a thing. And that it has only happen twice to me, and both in the same physical place, has gotten me reallying wondering. |
Re: Nav system rebooting while driving
Originally Posted by WaltPA
(Post 129207)
Originally Posted by TeeSter
(Post 129209)
You might want to clean and check your disk. It actually makes sense it would be in the same place. If the system in that location needs to load a new section of map from a different file and there is a defect on that exact file....
(Post 129226)
I wasn't navigating at all. It was just on the radio display.
So... even if you didn't have it in NAV mode, but the CD was in it could be loading a section of the map in the background, and crash on a dirty disk. |
(Post 129207)
I had this happen only once to me, and that was a few months ago. It was on a local road I rarely travel. Well, on Saturday, I was on that same road, and in just about the exact same spot, my Nav system went blank, and it then rebooted. :omg: I have no idea what could cause such a thing. And that it has only happen twice to me, and both in the same physical place, has gotten me reallying wondering. Unsuccessful repair efforts to date: 1) new head unit 2) new set of NAV CD's. 3) New power supply Ford is currently at a loss to resolve this. Anyone else been through this? |
Yes, the Nav system is always working in the background, even if you have just the radio on, and even if you have the unit "off" showing just black, or just the clock. It is always running, so long as you have a disc in. -John
Originally Posted by GatorJ
(Post 132044)
There is one stretch of road in a residential area where my NAV system reboots every single time. It has to have happened 25 times by now. It has happened in other areas as well, but not with that consistent level of regularity.
Unsuccessful repair efforts to date: 1) new head unit 2) new set of NAV CD's. 3) New power supply Ford is currently at a loss to resolve this. Anyone else been through this? My factory NAV did the same thing. The probelm stopped when I replaced the Factory NAV with an Eclipse 5510........ ~John |
Hi Walt -
It might not have had anything to do with what you were doing or a read error on the data disks. It quite possibly could have been your location, or to further explain, what you might have been near that caused the re-boot. This has happened to me many times but mostly in the same locations each time - but not every time - which would rule out a disk problem. It seems that every morning on my way to work, and sometimes on my return, at the exact same spot (on a bridge going over some railroad tracks) I don't get a full reboot but the display goes off (sometimes just all pixels) then it comes back up. I almost always have the FE screen up - it flashes the start-up ‘HYBRID’ screen then goes back to the FE screen. If I happened to be on the NAV screen it will come back up to the standard radio screen. The other place it happens each time I pass it the same thing happens - don't know what the culprit might be except maybe a Ham Radio etc. close by. The only thing I can think that is causing this is possibly an RF signal from a relay unit or something near or below the bridge that is interfering with the CPU. At first I thought that it might be that I had hit a bump or something and I had a loose connection. It has happened so many times in approximately the same place, even in different lanes, that the connection theory doesn’t jive. Hope this helps, |
Originally Posted by VietVet'67
(Post 132423)
Hi Walt -
My had the same issue only all the time constantly, but I fixed it by
-removing the disk -turnung the car off then on the the Nav system asked me to update new software have know Idea where if got it from -I click yes it updated rebotted It has worked fine since. |
