Nav System & Bluetooth
Old Nov 17, 2006 | 01:11 AM
  #51
greenhybrider's Avatar
Default Re: Nav System & Bluetooth
I took the NAV radio out today trying to install the Parrot 3200 LS, and I snapped some photos for reference too.
Back of Radio:
Ford Cables/Harness:
By the way, the cables on the Parrot 3200 LS are drastically different from the ones on the Visteon/Parrot 3100 unit that have been discussed previously on this thread. Now I'm studying how 3200 would fit on my NAV Radio, because the diagrams posted earlier on this thread doesn't seem to apply.
Here's a photo of the 3200 Harness:
Old Nov 17, 2006 | 01:18 AM
  #52
By the way, there's a site selling Parrot Harness Kits designed for various vehicles:
http://www.parrotkits.com/donotcut.html
I'm already in touch with the seller to determine if one of their harness would work with the FEH NAV Radio without splicing, "vampiring" and connecting extra wires.
Old Nov 17, 2006 | 07:59 AM
  #53
Tim K's Avatar
Actually, from the looks of the diagrams installation isn't that different at all. The confusing part is that they don't explain wires 5 and 6 (green and brown) in any of their documentation. I BELIEVE...and maybe mike can confirm this....but it looks to me from the Ford diagram and mike's installation that you DO NOT need to connect the speaker wires b/c the Ford Nav radio has Phone Audio inputs (pins 8 and 9). Therefore you just connect the un-mentioned green wire and brown wire from the Parrot kit to the 8 and 9 pins of the nav/accesory jack as shown in the diagram on page 2 of this thread.
Yellow Mute connects to pin 4 of the accessory/nav jack
Orange, Red and Black power wires connect to pins 3, 1 and 6 of the power jack
It seems MUCH easier and cheaper to install as mike's guys did by "vampire" connections and using pins than buying an adapter kit for $60 but that's just me. 6 wires and your done. Speaking of which, I'm ordering my Parrot kit today I think!!!
Old Nov 17, 2006 | 08:09 AM
  #54
Tim K's Avatar
All of this makes me wonder something else.....
If the Nav radio has a line-level input for phone devices.....(anyone guess where I am going with this???)....I wonder if one could run a line level output from, say an MP3 player or other such device like a satellite radio, to the line-in and just press the phone button to activate it......hmmmmmmmm
Old Nov 17, 2006 | 03:22 PM
  #55
If I'm not mistaken, when you look at the Parrot 3200 LS harness photo I posted, the extra "lines" are in red/black and brown/white bundles. There are no green and brown color wires. My first question: assuming the red and brown wires are the correct "lines" to connect to NAV jack, which of the two goes into 8 and which goes into pin 9 on the radio?
I don't see the green and brown wires from the Parrot 3200 Harness, unfortunately Parrot's manual/guide doesn't explain what these brown/white, red/black lines too either
Yes I think I can do this myself: attach a female connector to the end of the yellow wire and slide it into the ford NAV accessory jack. Right?!
This part I'm not sure. First question is, which one is the power jack?! Also, is this where I need to attach one of those vampire connectors to tap into the 12V ignition and battery power, like the photo here:
Yes there are only 6 wires, but for a non-electrician like me, I'm still trying to figure which things go where, but with you guys' help here, I'm learning a lot!
Old Nov 18, 2006 | 07:44 PM
  #56
Tim K's Avatar
I can't tell the colors in your photo, but based on the labels and Mike's diagram of his install it would appear that the dark wire from the 3200 labelled Line "-" should be connected to pin 9 of the Ford radio. The light wire labelled Line "+" should be connected to pin 8 of the Ford Radio.
That is correct from what I can tell. Crimp the connector to the end and stick it into the plug on the end of the bundle.
The connector on the top right with 7 slots is the power jack. The Red power wire from the 3200 labelled 12V ignition clips into the thick orange/green wire in pin 1, the Orange wire from the 3200 that I can't read clips into the yellow/black wire in pin 3, the black ground from the 3200 clips into the black/green wire in pin 6....all using the "vampire" connectors.
Old Nov 18, 2006 | 07:46 PM
  #57
Tim K's Avatar
FYI, I ordered my 3100 on Friday. I should have it sometime this week. I'll make sure to take installation photos and post them when I am done.
$135 delivered, not bad.
Old Nov 19, 2006 | 01:08 PM
  #58
WaltPA's Avatar
The Nav radio has just one line-level input for phones. I guess you could connect your MP3 player, but one would have to settle for listening to it in mono.
Old Nov 19, 2006 | 01:15 PM
  #59
WaltPA's Avatar
Can those be used "safely" on the thicker orange/green (+12v) wire and the thicker black/green (GND) wire? I am worried that such a connector might sever some of the internal wire strands when it is clamped on, substantially reducing that wire's current carrying capabilities.
Old Nov 20, 2006 | 01:10 AM
  #60
I apologize for the previous photo, I zoomed in on the original photo and reposted it with labels here:
What my previous photo doesn't show is, there are two wires lablelled "Line -" (Red and Brown) and two wires labelled "Line +" (White and Black).
My photo above only shows the stickers for white and brown wires only. The red and black wires also have the "Line -" and "Line +" stickers as well which I have labelled accordingly.
Now I'm confused because Pin 8 and 9 on Ford Jack should only accept one wire each? But when there are 2 wires for each "Line -" and "Line +", how do I choose?!
