to Mr. gray and the professional people here please help
hello everybody, i have at last find the problem of my ford escape hybrid 2005, which is the ventilation system of the HV battery, so can anyone provide me with the battery pack drawing to be able to uncover the battery and check its fans
and how many fans it has ??
i cant hear the fans working, please tell me is u can hear the fans clearly or not ???
and if i put the switch to unlock and take off the switch it self , is it safe to work with the battery ??
when i uncover the battery does it need any advanced programming or its just fix the cover and thats it ??
i know im asking alot of questions but i really need help from Mr. gray and the other professional people here in this forum,
and thanks in advance
The guy you were getting assistance from is Gary, not Mr. Gray. ![Wink](https://electricvehicleforums.com/forums/images/smilies/emotikons/wink.gif)
Regarding opening the battery pack to check the fans:
![Name: fordinternalbatteryheater-1.jpg
Size: 138.5 KB](/forums/attachments/ford-escape-hybrid-26/3033d1501530336-mr-gray-professional-people-here-please-help-fordinternalbatteryheater-1.jpg)
![Name: fordescapehybridbatteryopened.jpg
Size: 58.4 KB](/forums/attachments/ford-escape-hybrid-26/3034d1501530336-mr-gray-professional-people-here-please-help-fordescapehybridbatteryopened.jpg)
This is what your FEH battery pack looks like. My understanding is the FORD technicians are required to wear protective gloves rated to 1000 Volts. There is 330V inside this battery pack and it can KILL YOU
![Omg](https://electricvehicleforums.com/forums/images/smilies/emotikons/omg.gif)
about the battery, im sure its dangerous 300v is not a toy, but if we checked the fans at the far side of the battery and we take care of handling with the battery cells, and the mechanic is a professional guy but no experience in Hybrid cars, is there any possibility of damaging the battery ???
and the fans inside the battery, isnt there any possibility to be hanged or not working good and need a little maintenance ??
ive tried yesterday to hear the voice of the fans, and i didnt hear anything !! is that usual ?? plus that the battery temperature is 44c and not getting down and not using the EV !!!
dont u think the diagnostic is to be the battery cooling fans not working well ??
ive checked the AC, the fuses, the relays and the coolant pump, and all are ok ??
so please, is there anybody have any idea to me ?? i really need help from u all guys ###
The problem is, not many of us have had a battery fan failure, let alone opened our own battery pack to fix it. It's not recommended to open it up so I doubt any of us have done it.
Gary knows a lot about this because he reads a lot. Last I heard he said he wasn't able to help you much more, probably running out of things to check.
![Red face](https://electricvehicleforums.com/forums/images/icons/icon11.gif)
Even the Ford dealers with the most F E Hybrid experience have not serviced items inside the HV Battery. In the first several years of the FEH, if something inside the battery went bad (very very rare), they would change them out completely. The battery is well sealed and there is a filter for the incoming air to the fans.......therefore, it is highly unlikely that there is something simple that can be done to "fix" an internal fan. Only recently has it been reported that Ford Dealers are opening and servicing HVBattery components. (I do not remember if the harness recall work required the HVBattery to be opened) Is there something that may have happened to your FEH (an accident?) that may have broken the internal fans?
I suspect that neither Ford (nor Sanyo) even sell replacement internal fans or fan parts. In the US, the HVBattery is covered by an extended portion of the warranty - 8yrs and 100,000 miles (minimum).
Sorry to be so negative. This discussion may help you understand why there is very little help that others have to offer.
I have heard there is a small quantity of the HV Battery - for resale in the US - as they have found to be in good condition after being taken from FEHs that were bad accidents.
Good luck.
Good luck.
The fans do not run, or run very slowly when the car is not moving!
It is this way on purpose so you or back seat passengers do not hear the fans! The fans are variable speed and speed up as needed, when the vehicle speed increases.
It is very UNlikely the fans are not working.
It is very possible the A/C cooling system is not working, and/or the air door for the battery is not working.
HTH,
-John
HTH,
-John
