MMH Modulite Wiring
MMH Modulite Wiring
Hi All,
I bought a modulite for my tow wiring a while ago. I installed it using the wiring diagram from the shop manual. When I connected the 4-wire plug to the trailer, i noticed that it doesn't matter which which turn lights, left trailer light starts working. I couldn't figure out why. Is there anyone who made a wiring to MMH. I believe Walt had some experience. Can I get some color coded instructions, so that I can check my wiring? Could it be the modulite problem?I couldn't find any trouble shooting for it on the internet
Onur
Onur
Re: MMH Modulite Wiring
I bought the Valley wiring harness #30131. This plugs into the taillights on both sides, and then runs to a standard 4-pin trailer plug. However, I didn't stop there. I also got a Modulite #18193 to re-power the signals so that I don't screw up the Message Center.
I don't know the Mariner's wiring color coding, but I don't think that is required to know. One just plugs in the Valley harness into the tail light cables behind each tail light.
Also, for the Modulite, I had to run a wire up to the fuse box, located on the passenger side of the front console. Using a fuse tap, I was able to connect up to the required 10 amps.
An update on the trailer lights. I have a Modulite Protector. Modulite has Left Turn, Right Turn, Tail, Stop cables coming in and has Left Turn, Right Turn, Tail output. So the system combines turn signals and the stop light. MMH also combines the turn light and the stop light. So when I connected all inputs the modulite was getting confused. I disconnected the stop light input, everything became normal.
Onur
Onur
hiram6
06-21-2005 06:03 PM
