Make your own cabin air filter?
Old Jul 26, 2007 | 08:23 AM
TeeSter's Avatar
Default Re: Make your own cabin air filter?
Originally Posted by Mark E Smith
Semi bad news. According to my parts guy they are waiting on enough orders to ship, whatever that means. Either they have not made them yet or what? He mumbled something about one dealer have them all or something. I have email the company that was linked to see if they infact can get them.
"One dealer have them all"
and in the darkness there to sell them?
Okay..... it was a bit geeky but you can't spell gEEk without two EE's
Old Jul 26, 2007 | 08:32 AM
Mark E Smith's Avatar
Omnia Gloria Fugit
I just bought a 05 Mercury Sable CAF. It will work IF you build a bracket out of wood or something to seal the front and left side of the CAF and install it upside down. The front seal will need to be a triangle. The left seal is a simple ~3/4" square stock about 4" long. I will do some measuring, this could be a more economical setup once the seals are fabricated because you can purchase these filters at NAPA and other parts stores. I will post the dimensions later.
Old Jul 26, 2007 | 11:02 AM
Omnia Gloria Fugit
Simple solution! I got some 2" foam from a craft supply, don't need much. One piece about 4" X 2" X 1.5" another about 10.5" X 2" with one side tapered starting from about 5.5" tapering to about 3/4" at the end. (kinda self explanitory) Cut with a sharp utility razor. Install Sable filter upside down, stuff foam in to seal. I dont think you will have to glue it in place. I bought some velcro stickies just in case that way it can be removed to service the filter.
Old Jul 26, 2007 | 11:39 AM
Omnia Gloria Fugit
Works like a champ! There is a small reduction in air flow when you select OUTSIDE air, but there is no change in the recirculate mode (because it doesn't go through the CAF).
Napa cabin air filter part # 4773 fits 05 Mercury Sable.
Old Jul 26, 2007 | 02:37 PM
Omnia Gloria Fugit
Stopped by my friendly Ford dealer and talked to my parts guy. He showed me a picture of the 8L8Z-19N619-B cabin air filter and it is the one the 07's and 08's will need. It should drop right in and seal with no other mods. He thinks that they are for the 08's and since they are so new that they have not begun to ship the service parts.
Old Jul 26, 2007 | 02:49 PM
Omnia Gloria Fugit
As I suspected, this is the response I got from FordParts.com
Mark,
The part you have listed is for a 2008 model and is not yet available.
Thanks, Ken
FordParts.com
Old Oct 9, 2007 | 02:32 PM
  #27
ve7tcc's Avatar
I think 08 and 07 are the same format. I have an 08 FEH and did my own this weekend. It is a weird shape, like a trapezoid. I got some furnace filter material on a roll, about an inch thick, and cut it to shape roughly and had it folded over, so I have about 2 inch thick of filter.
Old Nov 26, 2007 | 03:24 PM
  #28
MyPart's Avatar
Has anyone actually received/installed a 8L8Z-19N619-B/FP-66 in an '07-'08?
dgyimao
Dec 31, 2009 09:38 AM
sanosteam
Dec 26, 2009 07:17 AM
bugs
May 26, 2009 12:05 AM
JamiEimaj
Jun 19, 2008 04:51 PM
