Maintenance question. Pressing the "SET" button
Old Nov 28, 2007 | 10:10 PM
Maverick-DBZ-'s Avatar
Question Maintenance question. Pressing the "SET" button
My 05 FEH just hit the 18,300+ mile mark. I noticed the left LCD on the bottom of the odometer asking me to press the "SET" button to do a "SYS CHUK" (system check). I press the "SET" button on the dash and notice the car is checking to make sure every thing is "OK". After it's done it just goes back to asking me to press the "SET" button again. Is there any way to get rid of the screen? All the checks turned out "OK" so I'm not sure what to do now.
Any advice?
Old Nov 28, 2007 | 11:12 PM
KermitCar's Avatar
It is easy being green
Default Re: Maintenance question. Pressing the "SET" button
on the left of the set button, there should be a button that says info. if you push it it will go through a menu about changing to metric and something else and then the spot will go blank, if you push it one more time, it will go back to mile till empty. hope this helps
Guss
Nov 23, 2010 06:53 AM
tigerhonaker
Oct 19, 2007 10:01 PM
belbe
Jul 4, 2007 12:33 PM
hybrid2
Mar 16, 2007 06:47 AM
jbollt
Aug 23, 2006 03:32 AM
