Low Gear Advantage While Braking?
Old Sep 23, 2011 | 12:55 PM
Default Re: Low Gear Advantage While Braking?
When in the L position when there is no more charge that the computer will send to the traction battery the negative split mode then kicks in and then uses compression braking on the ICE. Compression braking doesn't start until the traction battery has as much charge as is programmed to it.
When you brake in the L position the regen feature kicks in as mentioned above. The manuals also note that the rear brakes will be using friction braking. The front may also but the regen will divert some braking effort into the traction battery.
The Ford manuals note that the rear brake pads will wear twice as fast as the front brake pads because of this. As it turns out that's not quite what I saw. I use L for regen braking a lot.
Geckoboy
Jul 13, 2013 08:52 AM
Escape_from_Hanover
Dec 16, 2008 07:54 AM
Sky Blue
Aug 15, 2008 12:36 AM
GaryG
Apr 20, 2007 02:46 PM
Pexring
Sep 2, 2006 05:01 PM
