Looking for speaker sizes for 2008
Old Apr 19, 2008 | 05:48 AM
08FEH's Avatar
Default Looking for speaker sizes for 2008
Can anyone help with the front and rear speaker sizes used in the 08FEH.
Also, are there any depth issues when replacing factory speakers with aftermarket ones?
Thanks IA
08FEH
Old Apr 19, 2008 | 06:16 AM
pagemap's Avatar
Default Re: Looking for speaker sizes for 2008
You can go to this website and plug in your car info, and they will tell you what size speakers you need.
http://www.crutchfield.com/cgi-bin/a...r%2fMyCar.aspx
Old Apr 19, 2008 | 11:16 AM
Thanks IA
08FEH
You can use Crutchfield's information as I did. I replaced the stock speakers of my Mach system (25 watt max) with brand name speakers that were 6 by 8 inches. These fit perfectly as stated by Crutchfiled. To replace your door speakers you need to remove the inner door panel and you might as well use sound deadening material in the door and behind the speaker to improve on sound quality.
If you like sound quality--not necessary blasting loud noise--you may want to consider a 4 channel amplifier.
Old Apr 20, 2008 | 06:16 AM
08FEH's Avatar
Thanks for the info, it's exactly what I was looking for.
Sean
Old Apr 22, 2008 | 10:56 AM
tommyball's Avatar
Just a tip:
Be careful when removing the door panels. Specifically, the small (business card size) plastic cover pieces directly behind the actual inside door handle. These snap in place and once removed and reinstalled, never quite get back to where they were. I had to order replacement ones for two doors (less than $5) but it was still a pain when you look at how it's all put together and wonder why it can't be more sturdy.
-todd
jet1
10
Feb 9, 2014 06:54 PM
nmp27
Oct 22, 2010 01:00 PM
dcemureviews
Jun 22, 2009 08:28 AM
zimbop
Mar 26, 2009 02:55 PM
Hot_Georgia_2004
Jun 27, 2007 01:38 PM
