Let's talk tires...
Old Feb 4, 2009 | 01:28 AM
  #41
Default Re: Let's talk tires...
Actually, they are about $10 each cheaper here when you buy 4:
http://www.discounttiredirect.com/direct/home.do
But they are currently on AT LEAST a 14 day backorder.
The tires cost more individually, but you get $70 off when you buy 4.
Tire Rack says I'll have mine at my door in 3 days.
Which is good. I'm taking a 2000 mile trip in 4 days.
Old Feb 4, 2009 | 07:51 PM
  #42
MMooney's Avatar
I can't wait to hear if your mileage improves.
MM
Old Feb 4, 2009 | 10:25 PM
  #43
MM
Me too!
Here's the "problem".
When people change out their old paper air filter to a K&N filter, most report a slight increase in mileage. BUT....
Was this due to the change in type of filter? Or due to changing out a dirty one with a clean one? Or half & half?
Old, worn tires are smoother, well "broken in", and in general, give better MPG than new tires of the same type.
I'm changing the type, and the "newness" at the same time.
If my MPG remains constant, that could really be an improvement.
Catch my drift?
Old Feb 5, 2009 | 06:23 PM
  #44
MMooney's Avatar
Me too!
Catch my drift?
I am with you, but hopeful that the light weight alone will cause you to see some improvement.
MM
Old Feb 8, 2009 | 11:00 PM
  #45
Thumbs up Re: Let's talk tires...
Tire Rack shipped my Latitude Tours on Tuesday.
They were at my door by noon Thursday.
They were mounted to my car Friday.
I drove 1300 miles Sat & Sun.
I did a "coast down" test with my old tires down a hill in my neighborhood Thursday. On the 71,xxx miles Stock Eco Plus tires, I put the car in neutral and rolled down a hill to a stop, and marked it with chalk. I did this 3x and the car stopped with 10 ft. each time. I had the fronts at 38psi and the rears at 40psi.
Friday, I did the same test with the new tires, same psi.
The FEH rolled to the same spot +/- 5 feet out of half a mile coasting.
So no big difference there. But, no worse either!
The first thing I noticed right away is, the car is "bouncier"!
On the old tires, when I hit a pothole, or driveway, the car went "thud".
Now, the car feels like it goes "bounce bounce bounce" entering driveways, you know, where there is a gutter.
At 60 MPH on my long trip, was getting 40.2 MPG for a long ( 40 mile ) average. On the same roads, with the old tires, I was getting about 39 MPG.
At 71-72 MPH for a long ( 350 mile ) average, I got 31.5 MPG in one direction, and 32.0 MPG for the return trip. This was based on gas pumped. Nav was slightly higher, as usual. I think this is about 1.5 MPG higher than usual.
Hard to get specific, technical, reliable "proof" these tires are better.
But they for sure are not worse!
They do cost a little more ( ~33% more ) than the Continental Eco Plus, which, dollar per dollar, are probably just as good for your wallet.
The Michelin's have a longer (+25%) treadlife rating though.
HTH,
-John
P.S. No decernable change in "noise" level between the two tires. I always thought the Conti's were just fine, but the FEH has poor insulation and is a noisy car in the first place. I think when most people post that the stock tires are noisy, I think it is just the wind noise, since the whole car is loud. ( and louder than their last car )
Old Feb 9, 2009 | 02:10 PM
  #46
Matt D's Avatar
I have 9,200 miles on my '07, with the original Conti's, and my ride is rather quiet. I too agree that those complaining are just not used to a SUV. I came from a S-10, and must say my FEH rides smoother and is much quieter when comparing the two.
Old Feb 9, 2009 | 10:09 PM
  #47
MMooney's Avatar
HTH,
-John
Thanks very much for the update. Sounds like things are looking up!
Old Feb 10, 2009 | 04:08 PM
  #48
It was announced today the new VOLT will feature the Goodyear Assurance Fuel Max tires that feature a 27% decrease in rolling resistance over a "typical" tire. Bad news, a quick review of the Goodyear site fails to reveal any 235/70/16 sized tires.
Old Feb 10, 2009 | 04:35 PM
  #49
MyPart's Avatar
Best I can tell the Volt will be rolling on 21s (21 x 6.5 rims and 195/55R21 tires per this site). Good news is there should be plenty time to source some rims that will work out on the FEH
Old Feb 12, 2009 | 07:55 PM
  #50
gpcpilot's Avatar
Can't say I've had any noise issues with my OEM ContiTrac Eco tires on my '07 FEH. I'm not sure why or why not. It's a FWD with just under 30K miles. I do keep them aired up to 40psi all the time, so maybe that has something to do with it. But, they are as silent as the day I bought the FEH, except in the rain, when they hiss quite a bit.
Here is SoCal, that's not too often.
-Tony
